Discuss
Rober a
 in
Trash Compactor Repair
I have a Kenmore compactor modle#665.13605790. It compacts part way then sounds like it is stripping gears. then
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » Rober a
  #1 (permalink)
Old 02-08-2008, 11:19 AM
iapoppee iapoppee is offline
Junior Member
iapoppee is on a distinguished road
Question Rober a
then I have to turn the start knob to return the ram.
Can you tell me what might cause this problem?
Thank you.
  #2 (permalink)
Old 02-08-2008, 06:46 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Thank you.
There is a cycle switch on the left side of the control panel.
In what position is it?
__________________
  #3 (permalink)
Old 02-09-2008, 04:55 AM
Junior Member
Default
It is in the normal pack position.but I have tried both and it does the exact same thing.
  #4 (permalink)
Old 02-09-2008, 03:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check this switch for continuity.
When the switch is in "solid pack" position, the "O" & "O-B" circuit should be closed and the "O" & "Y" should be open.
When the switch is in "normal" position, the "O" & "O-B" circuit should be open and the "O" & "Y" should be closed.
Replace the switch if the reading is different.
In order to provide the right part number for the switch I need the color of the control panel.
__________________
  #5 (permalink)
Old 02-10-2008, 01:42 PM
Junior Member
Default
control panel is black in color
  #6 (permalink)
Old 02-11-2008, 12:38 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The part number for the cycle switch is AP3020726.
__________________
  #7 (permalink)
Old 02-11-2008, 03:09 PM
Junior Member
Default
Thanks Gene
Iwill get one and hopefuly that will fix my gear grinding compactor and make my wife a very happy camper.
  #8 (permalink)
Old 02-11-2008, 04:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
One more thing: if it's very noisy - most likely it is time for lubrication.
You can find the complete instructions in the one of my previous posts: jenn air Trash compactor
__________________
  #9 (permalink)
Old 04-20-2008, 12:21 PM
Junior Member
Default
Well Gene,I replaced the switch and lubed eveything.
The ram dosen't return and still sounds like stripped gears.
What now
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
