Discuss
Trash Compactor Solid Pack does not function
 in
Trash Compactor Repair
Hey Joe...THANK YOU as the part showed up in about 30 hours after I pressed send...WOW ! HOWEVER, as I
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » Trash Compactor Solid Pack does not function
  #11 (permalink)
Old 04-09-2013, 08:29 PM
Junior Member
frd1952 is on a distinguished road
Default
HOWEVER, as I feared the instruction sheet is missing one wire from the unit. The BLACK wire, thicker and from the 110 V plug wire itself is not mentioned at all in the instruction sheets ??? On the old switch, this wire was on the top connection of the White connection with the White wire being on the bottom. So the instruction sheet shows W goes to the W connection, my question is does the Black wire also go onto (top spot) of the W connection ? Also, FYI, the W wire is not long enough to reach the new spot on the other side of the new switch so you have to make a new W wire...just in case you have any input on things like the instruction sheet and this wire. Please confirm that the Black wire goes onto the same connection point as the W wire Joe....thanks, Frank
  #12 (permalink)
Old 04-10-2013, 07:07 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Frank, Let's try this, page 2 heading "4 Install new switch." of the instruction sheet, heading B. Connect motor leads to the new switch. This refers to the wires from the interior of the motor, and the terminals should be attached to the "lower" terminals of the new switch. Heading "C. Connect wire harness leads to the new switch" of course refers the the wire harness in the cabinet, and the terminals should be attached to the "upper" terminals of the new switch. The large "heavy guage black wire, should be the "neutral" leg of the power cord, and should attach the the upper W terminal of the new switch(pg.6 is the wiring diagram to refer to).
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #13 (permalink)
Old 04-10-2013, 01:12 PM
Junior Member
Default
Quote:
Great job Joe...all installed and working fine. THANK YOU for the help, patience, quick replies, quick shipping, and just generally great input and advice, etc etc. This has been fun and easy with your assistance. I really appreciate it.
Frank
  #14 (permalink)
Old 04-10-2013, 02:46 PM
Senior Expert
Default
Frank
Frank, You did all the work, you deserve the "Great Job"
We're just glad, we could meet or exceed your expectations, and get you up and going.
Thanks for the confidence and support.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Trash Compactor Solid (Locked) Cycle does not function dce Trash Compactor Repair 0 12-26-2011 09:15 AM
GE Monogram compactor wont solid pack Tedineaston Trash Compactor Repair 0 07-18-2011 10:38 AM
Won't raise after Solid pack. 860smapdi Trash Compactor Repair 2 09-10-2009 01:29 PM
Kitchen Aid trash compactor doesn't solid pack mkaminski Trash Compactor Repair 4 07-16-2009 06:53 PM
kitchen aid will not solid pack jwrubel1 Trash Compactor Repair 0 07-28-2008 03:25 PM
