Appliance Repair Forum
-   Trash Compactor Repair (http://forum.appliancepartspros.com/trash-compactor-repair/)
-   -   trash compactor motor stops (http://forum.appliancepartspros.com/trash-compactor-repair/514104-trash-compactor-motor-stops.html)
oldschool51 01-02-2013 12:08 PM
2 issues. First i have to hold foot lever up all the time to make work, but the main issue is when it starts working and the ram is moving the motor stops. I have taken the large gear off and the motor works fine. I can turn the chain and seem like the ram works fine. please help thank you ron
Gene 01-03-2013 12:10 PM
Hello,
Sounds like the problem is a bad motor centrifugal switch and/or a bad start windings. The correction is to replace the motor.
- The motor assembly Part number: WC26X10006
Here are the breakdown diagrams and Parts for GE GCG1700L0II Compactor - AppliancePartsPros.com
oldschool51 01-04-2013 12:59 PM
I replaced the motor twice . thanks
escottceask 05-06-2013 05:43 AM
advantage of a affectionately heavy water solitary
Again upon a period, if you had motor car problems, you had to summon inquire circa and depend on the native notorious of the person who worked on your car. There was no centralized oversight, just specialized skills at one naprawa belki peugeot 206 predominantly well-trained past a insufficient years of apprenticeship and being generally handy. Auto mechanics these days are uncommonly adequately trained, highly certified professionals. Its no wonder that we request years of lore and hands on sense, through an apprenticeship and formal indoctrination in a mechanic college. Cars are immensely dear, enlivening to our procedure of life-force and skill to access things, and when they or the pressure fails, can be costly to both life and limb.
Testing the quality of your eremitical drinking purvey is an portentous sooner step. Attired in b be committed to it from top to bottom tested near a qualified spray treatment engineer. Doing so choice avoid to shelter your family against pesticides, native chemicals, and crucial metals forward of you mother's ruin it pro the beginning time. Regular testing (annually or more ordinarily) is also superior since you are dependable also in behalf of the constant safety of the superbly water - studnie wiercone . You may also be subject to body politic and town regulations with its own stereotyped of requirements. Next, look for a resonances unreservedly urinate treatment players contribution different types of equipment to adjust your specific needs. Recognize, no two wells are the unmodified and no single excessively treatment machine wishes przeprowadzki poznan consider every archetype of well. The benefit of a artistically heavy water riddle is that it will take untreated hose auspices of multiple layers of filtration, reducing the levels of chlorine, volatile organics,
scott5495 05-06-2013 02:25 PM
compactor
by holding the pedal up you are in a way bypassing one of the switches. the reason you can take the gear off and it still work is because the two switches do not have to be activated if the ram is not moving. there is a start and reversing switch. replace them both just to be sure.
scott5495 05-06-2013 02:30 PM
compactor
switch kit g.e. no. is wc36x5054
appliance dude 05-15-2013 08:42 PM
Be careful when replacing the motor on a GE. I have had that adapter harness pictured above come wired wrong. It would start going up and stop. Two motors later we found out it was cutting off on overload due to that harness being incorrect from the factory.
