Discuss
GE monogram keeps spinning after just a bit of pressure
 in
Trash Compactor Repair
Hi --- my GE Monogram compactor will start compacting and when it gets a little pressure it will not go
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » GE monogram keeps spinning after just a bit of pressure
  #1 (permalink)
Old 06-25-2012, 09:51 PM
Junior Member
Burdad is on a distinguished road
Default GE monogram keeps spinning after just a bit of pressure
Brand: GE   Age: 1 - 5 years
Hi --- my GE Monogram compactor will start compacting and when it gets a little pressure it will not go down further, it keeps spinning. If I turn it off and back on again, it usually comes back up.
I did a test with the drawer out, it just gets stuck at the bottom of the cycle. I also noticed that where the screw comes out in front there is a plastic looking nut in a small case. That seems to have shattered or cracked. There are 2 nuts that hold this plate.
Any help would be appreciated. This is one of those 12 inch ones, my second and don't have much kitchen space. Thanks, Scott
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Monogram Cooktop Not Reliably Lighting (Pressure Regulator?) Franklin7777 Oven Repair (including Ranges and Cooktops) 0 01-10-2012 11:49 AM
Motor engages, sounds like it's spinning but inside tub isn't spinning. sheriscakes Washer Repair 2 10-26-2011 05:04 PM
GE dishwasher arm not spinning - not enough pressure? joshj392 Dishwasher Repair 1 04-20-2011 08:25 AM
No Pressure JTBarth Dishwasher Repair 4 04-07-2010 06:58 PM
Low water pressure and top spinners not spinning sfantin Dishwasher Repair 1 03-01-2009 02:05 AM
