Discuss
compacts then stops on way back up and hums
 in
Trash Compactor Repair
this will be the 2nd repair on this unit, 1st time wouldnt shut off and kept banging. motor gear cracked
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » compacts then stops on way back up and hums
  #1 (permalink)
Old 06-06-2012, 07:01 PM
Junior Member
bigdogzulu is on a distinguished road
Default compacts then stops on way back up and hums
Brand: Kitchen Aid   Age: 1 - 5 years
this will be the 2nd repair on this unit, 1st time wouldnt shut off and kept banging. motor gear cracked and ram would not raise and activate limit switch. that was an easy fix. 6 months later , unit stopped completly , jammed in down position. manually retracted by turning screws, got to a point it was hard to retract and would not turn, finally backed off enough to empty trash. both shafts seem to be straight and in time. put back together and ran , went down , contacted switch and reversed , made it half way and locked up again, is this a bad drive motor now
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana washer stops and hums mid-cycle powersct Washer Repair 0 08-12-2011 04:42 PM
Dryer hums and stops mid cycle diablo2011 Dryer Repair 0 08-07-2011 07:07 PM
Whirlpool Washer Starts Stops And Hums beverlyjean Washer Repair 1 06-02-2009 06:09 PM
intermittently stops, hums gmboetr Washer Repair 7 08-11-2008 02:49 AM
washer stops and hums, after cooldown starts again gmboetr Washer Repair 1 05-15-2008 06:42 PM
