| » Won't raise after Solid pack. |
Model Number: KUCP02IRBL1 Brand: Kitchen Aid Age: 1 - 5 years
Hi all,
I've got a Kitchenaid KUCP02IRBL1. My problem is that when a solid cycle is run, the ram never comes back up. I've tried cycling the dial to start and it just hums. I've also tried cycling the solid/normal switch to normal. I've disassembled the unit and I've found the when the ram is down and the motor is stopped but humming that I can get the motor to kick on by manual cycling the upper limit switch repeatedly. I've tested continuity on the wires and the upper limit switch according to the wiring diagram and the switch appears to be functioning. I've also disassembled the centrifugal switch and cleaned the breaker points. That switch appears to be functioning properly also. I tested the run and start windings and they looked ok. The start winding had 3.5ohms which is a bit on the low side but neither of the windings read open. Can anyone either point out an error in my method or perhaps shed light on which part of the system is at fault? I'm currently leaning on motor start windings. Thanks in advance for any information you can give me. Ads By Google Related Models |
Have you tested the cycle switch? It is a part of the push button switch and very likely the problem is there.
Here is the Tech sheet. - The cycle switch assembly Part number: AP3081046 Here are the breakdown diagrams for the Kitchen Aid trash compactor Model KUCP02IRBL1 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Yes. Cycle switch tested ok. I used a different method to test the windings and found the ccw start winding to be open. I'm not up to replacing the motor just yet so I bypassed the cycle select switch to disallow Solid from being used.
Thanks for the advice! Cheers |
| Display Modes | |
| How to raise dryer top? | wewelch | Dryer Repair | 2 | 02-13-2010 08:20 AM |
| Kitchen Aid trash compactor doesn't solid pack | mkaminski | Trash Compactor Repair | 4 | 07-16-2009 06:53 PM |
| Kenmore compactor ram won't raise | texaszinnia | Trash Compactor Repair | 3 | 11-09-2008 10:04 PM |
| kitchen aid will not solid pack | jwrubel1 | Trash Compactor Repair | 0 | 07-28-2008 03:25 PM |
