Discuss
Motor switch good, but not pressed
 in
Trash Compactor Repair
The ram hammers at the end of the stroke. I opened it up, tested the switches. They are all electrically
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » Motor switch good, but not pressed
  #1 (permalink)
Old 04-22-2012, 10:24 AM
Junior Member
LeftSpin is on a distinguished road
Default Motor switch good, but not pressed
Brand: Kenmore   Age: 1 - 5 years
The ram hammers at the end of the stroke. I opened it up, tested the switches. They are all electrically good. While watching the motor, I see that the switch is not pressed at the bottom of the ram stroke. When I press the plate which touches the motor switch, then the ram comes up again like it should. How do I fix or adjust this?
thanks!
Ads By Google
  #2 (permalink)
Old 05-12-2012, 11:28 PM
Junior Member
Default no help yet
any ideas on what is causing this?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Plastic shaft on dishwasher motor has shifted outward - needs to be pressed back? eltopo Dishwasher Repair 1 12-22-2010 12:48 PM
start switch give a good growl but motor not starting jonkertb Dryer Repair 3 09-15-2009 09:11 AM
Dryer motor will not go on when switch is pressed blue72 Dryer Repair 3 03-12-2009 05:52 PM
Dryer won't stay on unless "push to start" switch is continuously pressed in camalot Dryer Repair 1 01-29-2009 11:03 AM
lid switch...good or bad russ1 Washer Repair 20 11-20-2008 06:00 PM
