Discuss
jenn-air trash compactor broken gear?
 in
Trash Compactor Repair
My compactor ram is stuck in the down position.I took the side off and found that the white plastic gear(model
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » jenn-air trash compactor broken gear?
  #1 (permalink)
Old 04-19-2012, 12:02 PM
Junior Member
mljdd is on a distinguished road
Default jenn-air trash compactor broken gear?
Model Number: tc507   Brand: Jenn-Air   Age: 1 - 5 years
My compactor ram is stuck in the down position.I took the side off and found that the white plastic gear(model #882699) was broken in half. I tried grabbing the chain to see if I could manually move it by hand but the chain is very tight and would not budge...is the chain supposed to be that tight or is something stuck? My question is if I put this new gear on and the ram is stuck, will it break the new gear? Im not sure how to manually get the ram back to the up position.
Any help is greatly appreciated.
Thanks...Mike
Ads By Google
Related Models
Jenn-Air TC507B Compactor
Jenn-Air TC507Q Compactor
Maytag TC507S0 Compactor
Jenn-Air TC507W Compactor
Amana TC522G Ref - Top Mount
Amana TC522H Ref - Top Mount
Amana TC522K Ref - Top Mount
Amana TC522M Ref - Top Mount
Amana TC522N Ref - Top Mount
Amana TC522Q Ref - Top Mount
Maytag TC607S0 Trash Compactor
Maytag TC607X0 Trash Compactor
Whirlpool TC800SPDB0
Whirlpool TC800SPDB1
Whirlpool TC800SPDB2
Whirlpool TC800SPHB0
Whirlpool TC800SPJB0
Whirlpool TC800SPKB0
Whirlpool TC8700XBP0
Whirlpool TC8700XBP1
Whirlpool TC8700XYP0
Whirlpool TC8700XYP1
Whirlpool TC8700XYP2
Whirlpool TC8700XYP3
Whirlpool TC8700XYP4
Whirlpool TC8750XBP0
Whirlpool TC8750XBP1
Whirlpool TC8750XYP0
Whirlpool TC8750XYP1
Whirlpool TC8750XYP2
Whirlpool TC8750XYP3
Whirlpool TC900QPDB0
Whirlpool TC900QPDB1
Whirlpool TC900QPDQ0
Whirlpool TC900QPDQ1
General Electric TCD18PADARAA Refrigerator
General Electric TCD18PADARBB Refrigerator
General Electric TCD18PADARWW Refrigerator
General Electric TCD18PADBRAA Refrigerator
General Electric TCD18PADBRBB Refrigerator
General Electric TCD18PADBRWW Refrigerator
Whirlpool TCF0510DW00
Whirlpool TCF0510EW00
Whirlpool TCF0510EW01
Whirlpool TCF0510EW02
Whirlpool TCF0510EW03
Whirlpool TCF0510EW04
Whirlpool TCF0510EW05
Whirlpool TCF0510EW06
Whirlpool TCF0510GW00
Whirlpool TCF0510GW01
Whirlpool TCF0510GW02
Whirlpool TCF0510GW03
Whirlpool TCF0510GW04
Whirlpool TCF0510JW00
Whirlpool TCF0510JW01
Whirlpool TCF0700AW00
Whirlpool TCF0710AW00
Whirlpool TCF0710DW00
Whirlpool TCF0710EW00
Whirlpool TCF0710EW01
Whirlpool TCF0710EW05
Whirlpool TCF0710EW06
Whirlpool TCF0710GW00
Whirlpool TCF0710GW01
Whirlpool TCF0710GW05
Whirlpool TCF0710JW00
Whirlpool TCF0710JW01
Whirlpool TCF0710YW00
Whirlpool TCF1010FW00
Whirlpool TCF1010FW01
Whirlpool TCF1010FW02
Whirlpool TCF1010FW05
Whirlpool TCF1010FW06
Whirlpool TCF1010GW00
Whirlpool TCF1010GW01
Whirlpool TCF1010GW02
Whirlpool TCF1010GW05
Whirlpool TCF1510AW00
Whirlpool TCF1510DW00
Whirlpool TCF1510EW00
Whirlpool TCF1510EW01
Whirlpool TCF1510EW02
Whirlpool TCF1510EW03
Whirlpool TCF1510EW04
Whirlpool TCF1510EW05
Whirlpool TCF1510EW06
Whirlpool TCF1510GW00
Whirlpool TCF1510GW02
Whirlpool TCF1510GW05
Whirlpool TCF1510GW06
Whirlpool TCF1510WW00
Amana TCI-19D Misc / Accessory
Amana TCI-19E Misc / Accessory
Amana TCI-19LD Misc / Accessory
Amana TCI-19LE Misc / Accessory
Amana TCI18A3L Ref - Top Mount
Amana TCI18A3W Ref - Top Mount
Amana TCI18B Ref - Top Mount
Amana TCI18B-A Ref - Top Mount
Amana TCI18B-C Ref - Top Mount
Amana TCI18B-G Ref - Top Mount
Amana TCI18B-L Ref - Top Mount
Amana TCI18C Ref - Top Mount
Amana TCI18C-A Ref - Top Mount
Amana TCI18C-C Ref - Top Mount
Amana TCI18C-G Ref - Top Mount
Amana TCI18C-L Ref - Top Mount
Amana TCI18D Ref - Top Mount
Amana TCI18D-A Ref - Top Mount
Amana TCI18D-C Ref - Top Mount
Amana TCI18D-G Ref - Top Mount
Amana TCI18D-L Ref - Top Mount
Amana TCI18E Misc / Accessory
Amana TCI18E-A Misc / Accessory
Amana TCI18E-C Misc / Accessory
Amana TCI18E-G Misc / Accessory
  #2 (permalink)
Old 04-19-2012, 01:37 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Mike,
You have to check both power nuts (#13 at the diagram). If any one is bad, it will cause the ram to stuck. Also both power nuts, power screws and gears have to be lubricated.
- The power nut Part number: 9870163
- The drive gear kit Part number: 882699
Part number: 882699
- The lubricant Part number: AP3140802
Here are the breakdown diagrams and Replacement parts for Jenn-Air TC507B COMPACTOR | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 04-19-2012, 01:57 PM
Junior Member
Default jenn air trash compactor ram stuck!!!
Thanks for the help Gene....i will work on it wheh i get home. How hard is it to getto the power nuts?
  #4 (permalink)
Old 04-19-2012, 02:01 PM
Junior Member
Default
I meant how hard to get to the power nuts?
  #5 (permalink)
Old 04-19-2012, 02:39 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You have to remove the top cover and the ram. Be careful not to damage the top limit switch.
__________________
  #6 (permalink)
Old 04-19-2012, 05:55 PM
Junior Member
Default
Sounds hard specially with the ram being stuck
  #7 (permalink)
Old 04-20-2012, 08:02 AM
Junior Member
Default Jenn-Air ram stuck!!!
Hey Gene, how do you know if the power nuts are bad? Can I manually lift the ram back up and how?
Thanks again....Mike
  #8 (permalink)
Old 04-20-2012, 01:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Mike,
You may want to remove the top cover (at least) and look inside first. You may find some answers there.
P.S. You can bring the ram up by turning the powerscrew nut (#8 at the diagram) using an adjustable wrench.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kitchenaid compactor broken gear gudoc Trash Compactor Repair 0 10-10-2011 10:36 AM
Replacing Driven Gear in Trash Compactor calacci Trash Compactor Repair 0 01-25-2011 03:17 PM
Jenn Air Trash compactor idaboui Trash Compactor Repair 0 07-13-2010 05:37 PM
jenn air compactor drive gear fxcarden Trash Compactor Repair 4 01-14-2009 06:09 PM
jenn air Trash compactor bobg7 Trash Compactor Repair 4 02-03-2008 11:09 AM
