Discuss
Trash compactor repair
 in
Trash Compactor Repair
I have a Whirlpool trash compactor model GX900QPPB1. At the bottom of compaction stroke unit did not reverse, motor kept
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » Trash compactor repair
  #1 (permalink)
Old 08-03-2009, 11:19 AM
dmnovick dmnovick is offline
Junior Member
dmnovick is on a distinguished road
Default Trash compactor drive gear adjustments
Brand: Whirlpool   Age: 1 - 5 years
I have a Whirlpool trash compactor model GX900QPPB1. At the bottom of compaction stroke unit did not reverse, motor kept running in down direction and the nylon drive gears being stripped. Replaced both the motor and chain drive gears and the motor switch.
New switch (part # 780164) has contacts that are different than original switch (part #777971) but think switch is wired correctly. With new switch installed compactor operates but at bottom of compression stroke when motor reverses there is a loud pop. Compactor will then complete cycle and shut down at top of bin. During the up stroke the compactor runs a bit noiser than the down stroke.
At the bottom of the cycle the "pop" heard is the teeth of the motor drive gear “slipping” over the teeth of the chain drive gear. After the teeth slip the gear teeth engage and the ram moves in reverse to the top of the bin.
The relative position of the motor drive and chain drive gears is fixed - there is no way to adjust the gap between the gears. That said the gap between the motor and chain drive gear does not appear to be excessive. The position of the ram within the frame looks OK. The ram does not bind up on the sides of the frame on either the up of down stroke. All switches checked out OK. Tension of chain is within 1/4".
At some point the gear teeth are going to break. Any idea what is causing the gears to slip at the bottom of the stroke? Any suggestions on adjustments to make or parts to change out?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
G E trash compactor bobbyg Trash Compactor Repair 9 05-23-2009 09:21 PM
trash compactor oxoboxo2000 Trash Compactor Repair 0 02-25-2009 11:31 AM
GE Trash Compactor SRICHARDS Trash Compactor Repair 1 11-19-2008 06:56 AM
KitchenAid Trash Compactor foot pedal wont' open the compactor Tony Seaton Trash Compactor Repair 1 08-19-2008 01:03 AM
Trash Compactor MValley General Talk 1 08-17-2007 09:25 AM
