| » Plunger stops if I let off the on/off switch |
Model Number: KUCC151BWHO Brand: Kitchen Aid Age: 5 - 10 years
Symptoms -1) plunger stops unless I hold the on/off switch, 2) refuses to solid pack most of the time, and 3) power does not stop most of the time when it reaches the top.
Unless I continue to hold the on/off switch the plunger will immediately stop; if I hold the switch it works fine but as soon as I let off the plunger stops. I replaced the on/off switch but that did not help. I am wondering if I need to replace the solid pack switch too because most of the time it just refuses to solid pack. Do these two switches work off one another? I just replaced the inside flap switch which is supposed to stop the compactor when it reaches the top. It was working OK but now seems to have stopped working; ie the compactor continues to run when it returns to the top. I can see it flipping the flap which pushes the switch button which should make it go off - this doggone switch is only a few months old; it worked perfectly and turned off the compactor at first but has stopped working again. (In fact I think I bought it from you guys.) Appreciate your suggestions. Ads By Google Related Models |
Here is the Tech sheet.
Quote:
Quote:
Quote:
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUCC151BWH0 | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Gene - I will check the windings and the solid pack switch. Thanks for that.
The on/off switch is new; just installed it and it works exactly like the switch that I removed. In order for it to compact you must hold the switch; if you release it the power goes off, the plunger stops, and the next time you turn the switch you find that the motor direction has reversed. So I am not quite sure what to do. PS - top limit directional switch is new too. |
__________________
| Display Modes | |
| GE Gas dryer stops running when start switch is released | gevscott | Dryer Repair | 0 | 01-05-2010 02:54 PM |
| magnet, plunger fell out | allacy | Dishwasher Repair | 0 | 11-15-2009 09:03 AM |
| Kitchen Aid Compactor plunger remains down | aracadia | Trash Compactor Repair | 3 | 07-14-2009 05:31 PM |
| Drier stops when you release start switch | jhall82891 | Dryer Repair | 4 | 06-12-2009 04:18 AM |
| Solenoid plunger problem | Meg1223 | Dishwasher Repair | 13 | 08-25-2008 12:46 PM |
