chrisjames
#1 Posted : Tuesday, July 7, 2009 6:33:38 PM(UTC)
chrisjames
Help! I just got this compactor second hand from someone who was getting new appliances. It looks fine and all but has two problems:
1-The door doesnt quite sit straight, its like there is something small causing a misalignment on the right side, but the slides and rollers work beautifully.
2-It doesn't compact! When I try either mode (solid or normal) it makes noise like its working and then stops. If I hold the switch in the on or start position for a few seconds it does the same thing but when it would normally stop the whole machine just shuts down, filter and all! Then I smell something like a burning smell... I think my motor is going out, but I'm not sure...
Help!
#2 Posted : Wednesday, July 8, 2009 2:52:16 PM(UTC)
Make sure the latch on the right side of the container is locked properly.
Remove the top panel. Pull out the ram and check the power nuts (#12 on the diagram)
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUCC151GSS1 | AppliancePartsPros.com
Here are the Tech sheet.
