Discuss
Trash Ram uneven....
 in
Trash Compactor Repair
After compacting the trash ram returned to the top, but it is uneven. i.e., one side is lower than the
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » Trash Ram uneven....
  #1 (permalink)
Old 01-03-2012, 03:20 PM
Junior Member
tabsher is on a distinguished road
Default Trash Ram uneven....
Model Number: TU4100XTP0   Brand: Whirlpool   Age: More than 10 years
After compacting the trash ram returned to the top, but it is uneven. i.e., one side is lower than the other. The result is we cannot pull out the trash container.
Cannot seem to get the ram to return to a level position.
Any help on repair would be appreciated....
Tom
Ads By Google
Related Models
Whirlpool TU4100XTP0
Whirlpool TU4100XTP1
Whirlpool TU4100XTP2
Whirlpool TU4100XTP3
Whirlpool TU4700XBP0
Whirlpool TU4700XBP1
Whirlpool TU4700XXP0
Whirlpool TU4700XXP1
Whirlpool TU4700XXP2
Whirlpool TU8000XLP0
Whirlpool TU8000XRP0
Whirlpool TU8000XRP1
Whirlpool TU8000XRP2
Whirlpool TU8003XLP0
Whirlpool TU800SPDB0
Whirlpool TU800SPDB1
Whirlpool TU800SPDB2
Whirlpool TU800SPHB0
Whirlpool TU800SPJB0
Whirlpool TU800SPKB0
Whirlpool TU800SPKQ0
Whirlpool TU800SPPB0 Trash Compactor
Whirlpool TU800SPPB1 Trash Compactor
Whirlpool TU800SPPB2 Trash Compactor
Whirlpool TU800SPPQ0 Trash Compactor
Whirlpool TU800SPPQ1 Trash Compactor
Whirlpool TU800SPPQ2 Trash Compactor
Whirlpool TU8100XTP0
Whirlpool TU8100XTP1
Whirlpool TU8100XTP2
Whirlpool TU8100XTP3
Whirlpool TU8150XTP0
Whirlpool TU8150XTP1
Whirlpool TU8150XTP2
Whirlpool TU8700XXP0
Whirlpool TU8750XXP0
Whirlpool TU900QPDB0
Whirlpool TU900QPDQ0
Whirlpool TUD1000RB2 Undercounter Dishwasher
Whirlpool TUD2000W0
Whirlpool TUD2000W1
Whirlpool TUD2000W3
Whirlpool TUD2000W4
Whirlpool TUD2000W5
Whirlpool TUD2000W6
Whirlpool TUD2000W7
Whirlpool TUD2000Y0
Whirlpool TUD3000W0
Whirlpool TUD3000W1
Whirlpool TUD3000W2
Whirlpool TUD3000Y0
Whirlpool TUD3000Y1
Whirlpool TUD3000Y2
Whirlpool TUD3000Y3
Whirlpool TUD3000Y4
Whirlpool TUD3000Y5
Whirlpool TUD3000Y6
Whirlpool TUD4000EB0
Whirlpool TUD4000EB1
Whirlpool TUD4000EB2
Whirlpool TUD4700KB0
Whirlpool TUD4700KB1
Whirlpool TUD4700KQ0
Whirlpool TUD4700KQ1
Whirlpool TUD4700MQ0 Undercounter Dishwasher
Whirlpool TUD4700MQ1 Undercounter Dishwasher
Whirlpool TUD4700MQ2 Undercounter Dishwasher
Whirlpool TUD4700MU0 Undercounter Dishwasher
Whirlpool TUD4700MU1 Undercounter Dishwasher
Whirlpool TUD4700MU2 Undercounter Dishwasher
Whirlpool TUD4700SQ0 Undercounter Dishwasher
Whirlpool TUD4700SQ1 Undercounter Dishwasher
Whirlpool TUD4700SU0 Undercounter Dishwasher
Whirlpool TUD4700SU1 Undercounter Dishwasher
Whirlpool TUD5000Y0
Whirlpool TUD5000Y1
Whirlpool TUD5000Y2
Whirlpool TUD5000Y3
Whirlpool TUD5000Y4
Whirlpool TUD5700EQ0
Whirlpool TUD5700EQ2
Whirlpool TUD5700EQ3
Whirlpool TUD5700EQ4
Whirlpool TUD5700EQ5
Whirlpool TUD5700KB0
Whirlpool TUD5700KQ0
Whirlpool TUD5700MBO Undercounter Dishwasher
Whirlpool TUD5700MQ0 Undercounter Dishwasher
Whirlpool TUD6000JQ0
Whirlpool TUD6000KB1
Whirlpool TUD6000KQ1
Whirlpool TUD6000KT1
Whirlpool TUD6700KB0 Undercounter Dishwasher
Whirlpool TUD6700KQ0 Undercounter Dishwasher
Whirlpool TUD6700KS0 Undercounter Dishwasher
Whirlpool TUD6700KT0 Undercounter Dishwasher
Whirlpool TUD6700PB0 Undercounter Dishwasher
Whirlpool TUD6700PB2 Undercounter Dishwasher
Whirlpool TUD6700PQ0 Undercounter Dishwasher
Whirlpool TUD6700PQ2 Undercounter Dishwasher
Whirlpool TUD6700PS0 Undercounter Dishwasher
Whirlpool TUD6700PS2 Undercounter Dishwasher
Whirlpool TUD6700PT0 Undercounter Dishwasher
Whirlpool TUD6700PT2 Undercounter Dishwasher
Whirlpool TUD6710PB0 Undercounter Dishwasher
Whirlpool TUD6710PB1 Undercounter Dishwasher
Whirlpool TUD6710PB2 Undercounter Dishwasher
Whirlpool TUD6710PQ0 Undercounter Dishwasher
Whirlpool TUD6710PQ1 Undercounter Dishwasher
Whirlpool TUD6710PQ2 Undercounter Dishwasher
Whirlpool TUD6710PT0 Undercounter Dishwasher
Whirlpool TUD6710PT1 Undercounter Dishwasher
Whirlpool TUD6710PT2 Undercounter Dishwasher
Whirlpool TUD6710SB0 Undercounter Dishwasher
Whirlpool TUD6710SQ0 Undercounter Dishwasher
Whirlpool TUD6750RD0 Undercounter Dishwasher
Whirlpool TUD6750RD1 Undercounter Dishwasher
Whirlpool TUD6750RD2 Undercounter Dishwasher
Whirlpool TUD6750SD0 Undercounter Dishwasher
Whirlpool TUD6900PB0 Undercounter Dishwasher
  #2 (permalink)
Old 01-16-2012, 05:30 AM
Junior Member
kdog021 is on a distinguished road
Default Uneven ram
The ram in your compactor wouldn't be uneven unless something else had also gone wrong. The left and right sides of the ram are fastened to steel power nuts that ride up and down on two power screws. The bottom end of those screws end in sprockets connected to each other via a chain. Since that ram was, once upon a time, level, either the ram itself has bent (unlikely) or one side has slipped relative to the other.
Pull the compactor out, disconnect the power, and remove the top cover and motor cover. Look at everything you see here: broken, bent or loose parts. You may be able to rotate the motor to raise the ram and get the trash drawer out. If not, you'll need to turn the compactor on its side and remove the bottom panel, which is where you'll find the gears, chain, and sprockets. Inspect these carefully: is the chain loose enough to slip? Are teeth missing on any of the sprockets? Is the main (plastic) drive gear cracked? If you turn the motor by hand, does everything move correctly?
If you need to remove or adjust the chain, loosen the bolts holding the motor/drive gear assembly. The motor can slide enough to slip the chain off of the sprockets. With the chain off, you can rotate either power-screw sprockets independently and level your ram out. (You could also level the ram by raising it more; the "high" side will top out first and the ram will level itself, but this "fix" doesn't answer the question of how your compactor got this way in the first place!)
The most difficult repair will be if the power screws or power nuts are worn out (or stripped); that's probably the point at which I'd consider a service call (or a new compactor, which may not cost much more than those parts!)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
uneven heat adjustablekicker Oven Repair (including Ranges and Cooktops) 0 04-04-2011 03:53 PM
Uneven heating of oven whiz67 Oven Repair (including Ranges and Cooktops) 0 12-30-2009 09:47 AM
Wall Oven Uneven foutz Oven Repair (including Ranges and Cooktops) 0 12-11-2009 03:29 PM
Uneven Conv. Heating debjoecarrie Oven Repair (including Ranges and Cooktops) 4 09-26-2009 05:41 PM
