Discuss
Door won't shut correctly
 in
Trash Compactor Repair
On a Kenmore model 665-1361 the door will not catch correctly when you slide it in. If you lift
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » Door won't shut correctly
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-31-2007, 03:35 PM
sportbuffs sportbuffs is offline
Junior Member
sportbuffs is on a distinguished road
Default Door won't shut correctly
On a Kenmore model 665-1361 the door will not catch correctly when you slide it in. If you lift it slightly it and moveto the right, it will close correctly. The foot pedal also does not work correctly.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
my oven is shut down munequita4u2 Oven Repair (including Ranges and Cooktops) 7 05-29-2008 12:49 PM
oven will not heat correctly Jolehouse Oven Repair (including Ranges and Cooktops) 1 12-17-2007 06:21 PM
Oven not heating correctly j_bates23 Oven Repair (including Ranges and Cooktops) 1 12-07-2007 06:26 PM
How do I put belt on correctly too much slack Stacie Dryer Repair 0 11-06-2007 12:15 PM
Front loader not spinning correctly Ferm2374 Washer Repair 0 08-10-2007 05:07 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
