| » Foot Pedal drawer opener and compactor activation |
Model Number: GE gcg1500 L Brand: GE Age: 1 - 5 years
Hi all I am new here and I have a problem with my compactor. The foot activator all of a sudden felt really loose when you would wiggle it up and down. You step on it to open the door and push it up to activate the ram. I tried to tighten the phillips head screw on one of the sides and it was stiff but then turned and did not tighten. Now it is worse. The compactor door still opens and the ram works but it feels like something breaks in the lever every time you operate it. How can I replace it or fix it? John
Remove the container, put it on its side and inspect the foot pedal. Make sure the compactor cabinet is clean inside. If the pedal is damaged you have to remove the screw on each side holding the pedal. Be careful not to lose them because those screws are very special.
Here are the breakdown diagrams and Replacement parts for GE GCG1500L0BB | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com Last edited by Gene : 06-18-2009 at 01:49 PM. |
I also found that after 2 years my GE Profile Trash Compactor (purchased in June '07), the pedal was hanging down on the left side. I searched the internet and called GE to no avail.
After a few attempts, I finally solved the problem by removing the screw on the left side and adding a metal "L" bracket, with the bottom of the L flush against the back of the front panel. That way, when you depress the pedal, the screw can't pop out of the metal it's attached to. Good luck! Dannys00 |
the retaining screws on the foot pedal which attach to the bin are defective design. Thye will fail after approximately 500 cycles . The sheet metal of the bin is an issue. The srews go through the sheet metal but the screw rotates on the the hole and causes failure of the hole. The symptom is ahard opening drawer and loose pedal. Call GE and complain
Danny: I'm having the same problem and I like your idea, but would you please describe it more; not sure I understand exactly how to position the "L" bracket, what type / size of bracket, etc.
Thanks, Steve Quote:
| Display Modes | |
| GE compactor foot pedal broken, won't open | jhunt | Trash Compactor Repair | 3 | 12-24-2009 05:44 PM |
| Loose drawer handle on bottom freezer drawer | daman0727 | Refrigerator & Freezer Repair | 2 | 06-26-2009 03:36 PM |
| KitchenAid Trash Compactor foot pedal wont' open the compactor | Tony Seaton | Trash Compactor Repair | 1 | 08-19-2008 12:03 AM |
| Kitchen Aid Trash Compactor Drawer Slides | Jim Michalek | Trash Compactor Repair | 2 | 03-06-2008 05:11 PM |
