Unit will run as long as you hold the pedal up it will cycle all the way and just keep running until you let the pedal go.If you let the pedal go it quits immediatly were ever the ram is.I put a new motor in 2 yrs ago
because of the goofy plastic on off switch that burns up( not sold separately). it worked fine till now. It use to run when you pop the pedal up and it would cycle and quit. the pedal would reset. Also is the pedal attachment on the left side a slot instead of a drilled hole like the right or is it just worn out .How to fix? Thanks in advance! Walt
