Discuss
Manual retraction of ram stuck in down position
 in
Trash Compactor Repair
Ram stuck in down position. Power to electrical box, but no apparent power to unit. Is there a way to
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » Manual retraction of ram stuck in down position
  #1 (permalink)
Old 11-12-2011, 10:14 AM
Junior Member
bmcmohr is on a distinguished road
Default Manual retraction of ram stuck in down position
Model Number: 2000   Brand: Signature   Age: More than 10 years
Ram stuck in down position. Power to electrical box, but no apparent power to unit. Is there a way to manually retract ram so we can empty container?
Thanks.
Related Models
Hoover 2000
Hoover 2001
Amana 2008.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2008.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2008.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2008.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2008.100 COMMERCIAL MICROWAVES
Amana 2008.101 COMMERCIAL MICROWAVES
Amana 2008.102 COMMERCIAL MICROWAVES
Amana 2008.112 COMMERCIAL MICROWAVES
Amana 2009.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2009.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2009.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2009.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 200A-30 ROOM AIR CONDITIONER
Amana 200A-30H ROOM AIR CONDITIONER
Amana 200A-3HN ROOM AIR CONDITIONER
Amana 200A-3M ROOM AIR CONDITIONER
Amana 200A-3N ROOM AIR CONDITIONER
Amana 200A-3P ROOM AIR CONDITIONER
Amana 200A-3PH ROOM AIR CONDITIONER
Amana 200A-3R ROOM AIR CONDITIONER
Amana 200A-3RH ROOM AIR CONDITIONER
Amana 200C-3P ROOM AIR CONDITIONER
Amana 200C-3PH ROOM AIR CONDITIONER
Amana 200C-3R ROOM AIR CONDITIONER
Amana 200C-3RH ROOM AIR CONDITIONER
Amana 200C-8P ROOM AIR CONDITIONER
Amana 200C-8RH ROOM AIR CONDITIONER
Amana 201.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 201.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 201.700 MWAVE - FAMILY SIZE (60 HZ)
Hoover 2010
Hoover 2011
Jenn-Air 20135 RANGE- S/C D/I DDRAFT ELE
Hoover 2017
Amana 2018.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2018.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2018.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2018.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2022.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2022.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2022.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2022.004 MWAVE - FAMILY SIZE (60 HZ)
Jenn-Air 20236 RANGE- S/C S/I DDRAFT ELE
Jenn-Air 20237 RANGE- S/C S/I DDRAFT ELE
Jenn-Air 20239 RANGE- S/C S/I DDRAFT ELE
Roper 2025B0A Ranges, Electric*
Roper 2035B0A Ranges, Electric*
Roper 2035B1A Ranges, Electric*
Amana 2036.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2036.005 MWAVE - FAMILY SIZE (60 HZ)
Amana 2036.104 COMMERCIAL MICROWAVES
Amana 2036.105 COMMERCIAL MICROWAVES
Amana 2039.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2039.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2039.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2039.004 MWAVE - FAMILY SIZE (60 HZ)
Hoover 2040
Roper 2045B0A Ranges, Electric*
Roper 2045B1A Ranges, Electric*
Hoover 2048
Amana 2052.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2052.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2052.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2052.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2054.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2054.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2054.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2054.004 MWAVE - FAMILY SIZE (60 HZ)
Roper 2055B0A Ranges, Electric*
Roper 2055B1A Ranges, Electric*
Roper 2055B2A Ranges, Electric*
Roper 2065B0A Ranges, Electric*
Roper 2065B1A Ranges, Electric*
Roper 2065B2A Ranges, Electric*
Amana 2070.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2070.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2070.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2070.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2071.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2072.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2072.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2072.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2072.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2074.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2074.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2074.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2074.004 MWAVE - FAMILY SIZE (60 HZ)
Roper 2075B0A Ranges, Electric*
Roper 2075B1A Ranges, Electric*
Roper 2075B2A Ranges, Electric*
Amana 2085.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2085.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2085.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2085.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2089.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2090.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2090.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2090.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2091.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2092.004 MWAVE - FAMILY SIZE (60 HZ)
Roper 2092B0A Ranges, Electric*
Roper 2092B1A Ranges, Electric*
Roper 2092B2A Ranges, Electric*
Roper 2092B3A Ranges, Electric*
Amana 2094.004 MWAVE - FAMILY SIZE (60 HZ)
Roper 2095B0A Ranges, Electric*
Roper 2095B1A Ranges, Electric*
Roper 2095B2A Ranges, Electric*
Amana 210-3B ROOM AIR CONDITIONER
Hoover 2100
Roper 2101*0E Ranges, Electric*
Roper 2101*1E Ranges, Electric*
Roper 2101*2E Ranges, Electric*
Amana 21011 COMMERCIAL MICROWAVES
Amana 21016 COMMERCIAL MICROWAVES
Roper 2101W0E Ranges, Electric*
Roper 2101W1E Ranges, Electric*
Roper 2101W2E Ranges, Electric*
  #2 (permalink)
Old 12-12-2011, 04:38 PM
Junior Member
tuffys1 is on a distinguished road
Default
Quote:
Thanks.
Typically pretty easy. Many compactors are sourced from the same mfg. Disconnect electrical source. Pull the compactor out and gently lay on its side. Remove the bottom panel and you will see a large drive gear (mine's plastic) that may be broken and the cause of your problems.
In any event you can turn that gear to move the ram. You will likely need a sock wrench to turn the nut in the center of the gear as it may be very difficult to turn by hand. Turn the gear counter clockwise to raise it. If the gear is broken parts are relatively inexpensive and easy to replace.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Compactor Ram stuck in down position patriot1 Trash Compactor Repair 0 11-01-2011 12:51 PM
Trash Compactor Stuck in down position gideon1234 Trash Compactor Repair 0 02-07-2011 05:02 PM
Trash compactor ram stuck in down position John W G Trash Compactor Repair 0 01-05-2011 06:09 PM
kenmore dish stuck in open position mtillman3 Dishwasher Repair 0 01-07-2010 07:02 AM
kenmore dish stuck in open position mtillman3 Dishwasher Repair 1 01-04-2010 08:17 PM
