Discuss
Kenmore Model 665.13614100
 in
Trash Compactor Repair
Motor windings decided to short (oh the ozone) and the compactor jammed mid-cycle. Ordered replacement motor which arrived in
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » Kenmore Model 665.13614100
  #1 (permalink)
Old 12-12-2007, 07:24 PM
dhenderson dhenderson is offline
Junior Member
dhenderson is on a distinguished road
Cool Kenmore Model 665.13614100
Motor windings decided to short (oh the ozone) and the compactor jammed mid-cycle. Ordered replacement motor which arrived in a matter of days (most impressive). Unfortunately. in process of figuring out how to get at the motor and unjam the system, I disconnected the front panel (which comes back to bite me).
Now... I took photos of wiring on the motor before disconnecting. I hooked the replacement up to match the photos. Didn't think to take photos of the front panel connections as they looked simple. Instead, wife wrote down what I described which when read back now makes no sense.
Reassembled, the compactor works in one of two extremes: it will not run -or- it will not stop running.
I've played with the front panel wiring, but cannot get it right. Can I get a diagram that describes what color wires connect to which spade connector on the front panel for this model? I have the circuit diagrams, but that doesn't help me too much.
Alternatively, if I post pics of the front panel wiring can someone tell me which wires go where?
One minor caveat: The wiring instructions with the replacement motor did not match the original install based on the photos. So I went with the photos.
Thanks!
- Dave
  #2 (permalink)
Old 12-12-2007, 08:01 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
If you post the pictures and the wiring diagram, it might help.
__________________
  #3 (permalink)
Old 12-13-2007, 08:53 PM
Junior Member
Default
Quote:
Three photos attached. DSC06633 is unit face showing switches. Round dial actuates the unit. Buttons on the left panel place the unit into constant compression or release. Left to right it corresponds to wiring shown in other photos.
DCS06632 and DSC06634 are of the wiring as I have it connected currently.
The PDF is of the wiring diagram found inside of the unit.
Appreciate the assist. Please let me know if you need anything more.
Thanks!
- Dave
  #4 (permalink)
Old 12-14-2007, 11:42 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
All terminals on the start-run and the cycle switches are marked according to the wires color code. In double colored wires the first letter means the color and the second letter means the stripe.
T-R is for the Tan wire with the Red stripe.
O-BK is for the Orange wire with the Black stripe.
Looks like you connected some wires incorrect.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Model PSS26NGSC Compressor rksanderson Refrigerator & Freezer Repair 5 01-30-2008 09:24 PM
Kenmore model 110.46472501 sewer odor rbell Washer Repair 1 12-29-2007 05:07 PM
Kenmore series 70, model 110 makes clunking noise? washerTed Washer Repair 1 11-18-2007 05:36 PM
correction to model number slangzang Dishwasher Repair 3 11-11-2007 06:11 PM
Kenmore Clothes Dryer No Heat -Model 110.62994101 HRichburg Dryer Repair 5 09-30-2007 10:20 AM
