| » Kenmore Model 665.13614100 |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Motor windings decided to short (oh the ozone) and the compactor jammed mid-cycle. Ordered replacement motor which arrived in a matter of days (most impressive). Unfortunately. in process of figuring out how to get at the motor and unjam the system, I disconnected the front panel (which comes back to bite me).
Now... I took photos of wiring on the motor before disconnecting. I hooked the replacement up to match the photos. Didn't think to take photos of the front panel connections as they looked simple. Instead, wife wrote down what I described which when read back now makes no sense. Reassembled, the compactor works in one of two extremes: it will not run -or- it will not stop running. I've played with the front panel wiring, but cannot get it right. Can I get a diagram that describes what color wires connect to which spade connector on the front panel for this model? I have the circuit diagrams, but that doesn't help me too much. Alternatively, if I post pics of the front panel wiring can someone tell me which wires go where? One minor caveat: The wiring instructions with the replacement motor did not match the original install based on the photos. So I went with the photos. Thanks! - Dave |
If you post the pictures and the wiring diagram, it might help.
__________________
Professional appliance repair services in Orange County, California. |
Quote:
DCS06632 and DSC06634 are of the wiring as I have it connected currently. The PDF is of the wiring diagram found inside of the unit. Appreciate the assist. Please let me know if you need anything more. Thanks! - Dave |
All terminals on the start-run and the cycle switches are marked according to the wires color code. In double colored wires the first letter means the color and the second letter means the stripe.
T-R is for the Tan wire with the Red stripe. O-BK is for the Orange wire with the Black stripe. Looks like you connected some wires incorrect. Gene.
__________________
| Display Modes | |
| GE Model PSS26NGSC Compressor | rksanderson | Refrigerator & Freezer Repair | 5 | 01-30-2008 08:24 PM |
| Kenmore model 110.46472501 sewer odor | rbell | Washer Repair | 1 | 12-29-2007 04:07 PM |
| Kenmore series 70, model 110 makes clunking noise? | washerTed | Washer Repair | 1 | 11-18-2007 04:36 PM |
| correction to model number | slangzang | Dishwasher Repair | 3 | 11-11-2007 05:11 PM |
| Kenmore Clothes Dryer No Heat -Model 110.62994101 | HRichburg | Dryer Repair | 5 | 09-30-2007 09:20 AM |
