Discuss
connecting the wires to the Centrifugal Switch
 in
Trash Compactor Repair
Originally Posted by jeffreybryer I have a Kitchenaid Trash compactor-in May 2009, i replaced the centrifugal motor switch (with a
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » connecting the wires to the Centrifugal Switch
  #11 (permalink)
Old 09-03-2010, 04:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by jeffreybryer View Post
I have a Kitchenaid Trash compactor-in May 2009, i replaced the centrifugal motor switch (with a bit of help) and recently replaced the Upper limit switch thinking that it was the reason that the ompactor wouldn;t stop at the top of the cycle & turn off. After replacing the ULS, i've found that it just continues so-was it the ULS after all? I just checked the Solid Compact switch-when turned on-it still returns to the top position instead of remiaing inside the bucket/can & again, it does not stop cycling & makes the tamping sound until i open the toe kick & it cuts off. I've checked ohms on the switches & now i'm going to look at the actual motor while it cycles. I don't know what else to do? I wonder if the new Top Limit Switch has four (4) different settings and perhaps i moved the lever? It sounds like it does when i click it-at least two then. I tried to reset it with the top off of the trash compactor but even when i tried to click the upper / top limit switch, the ram wouldn't turn off or stop. This has been going on way too long for me & my family-i would have ben better off calling sears a long time ago-i'm just trying to save $$$-it's so tight i don't know if we'll be here next month! LMK if you can help!
THank you again:-)
Sorry we missed your post.
If it's not too late, you may want to check the momentary start switch (#14 on the diagram). If this switch is stuck closed, then the power to the motor start windings would not interrupt.
- The momentary start switch Part number: AP3180527
Ads By Google
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #12 (permalink)
Old 09-03-2010, 05:07 PM
Administrator
APP Team
Adam / APP Team is on a distinguished road
Default
I don't understand a word that the poster published & I am sure that Repair Forum would not allow this to be placed onto any of their site blogs, forums or otherwise.
Thanks jeffreybryer for making us aware of the spam. If you find more please click on the red triangle to report it.
__________________
Need a part? Buy appliance parts from us. Fast delivery and great prices.
Thank you for supporting our free repair help forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana Speed Queen Dryer- Need Help connecting wires correctly djhogge Dryer Repair 1 02-22-2010 07:46 AM
infinite switch wiring change from 6 wires to 5 wire switch wiedemanndds Oven Repair (including Ranges and Cooktops) 5 11-24-2009 02:14 PM
Connecting New Selector Switch sickappliancerepair Oven Repair (including Ranges and Cooktops) 1 04-16-2009 02:36 AM
Dryer Switch Assembly Wires tkelly45 Dryer Repair 0 10-01-2008 09:09 AM
Trash compactor Centrifugal switch msehome Trash Compactor Repair 0 10-02-2007 05:44 AM
