Discuss
Replacing compactor belt
 in
Trash Compactor Repair
My 30 year old KitchenAid trash compactor has a broken belt. The belt broke just as the compactor was starting
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » Replacing compactor belt
  #1 (permalink)
Old 11-26-2007, 06:32 AM
lcb lcb is offline
Junior Member
lcb is on a distinguished road
Default Replacing compactor belt
My 30 year old KitchenAid trash compactor has a broken belt. The belt broke just as the compactor was starting to compress so the drawer will not open. Found a replacement belt but am wondering if this is a DIY job or should be referred to an experienced repairman. Looks to me like the work will need to be done through the opening in the top of the appliance and I don't know how many parts need to be removed in order to install the replacement belt. Any help will be appreciated.
  #2 (permalink)
Old 11-26-2007, 03:28 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
In order to provide the most accurate advise I need the complete model number of the trash compactor.
__________________
  #3 (permalink)
Old 11-26-2007, 05:27 PM
lcb lcb is offline
Junior Member
Default
The model# is KCS-100B
  #4 (permalink)
Old 11-26-2007, 07:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You have to remove the t/c from the cabinet, remove the top panel and find out what part(s) is bad. It could be the belt or the chain.
- Here are the break down diagrams for the Kitchen Aid trash compactor Model KCS100B
__________________
  #5 (permalink)
Old 11-27-2007, 10:28 AM
lcb lcb is offline
Junior Member
Default
Received diagrams and have ordered replacement belt. Thanks for your assistance.
  #6 (permalink)
Old 11-27-2007, 10:31 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Keep me updated, please.
__________________
  #7 (permalink)
Old 11-30-2007, 03:25 AM
lcb lcb is offline
Junior Member
Default
Gene,
Replacement belt arrived and I installed it yesterday afternoon. Compactor works as well as before. $26. for the belt and your assistance saved me a service call and several hundred dollars over a replacement compactor. I had already decided I would not spend a lot of money on a 30 year old appliance. Thanks for your help.
Larry
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Compactor is noisey DDavidR Trash Compactor Repair 1 09-07-2009 09:40 AM
Compactor won't open Frank I Trash Compactor Repair 3 02-04-2008 10:44 PM
compactor ninabobina Garbage Disposer Repair 1 11-07-2007 06:56 PM
Garbage Compactor flaumbetty Trash Compactor Repair 3 10-04-2007 03:02 PM
Trash Compactor MValley General Talk 1 08-17-2007 09:25 AM
