Discuss
Compactor won't open
 in
Trash Compactor Repair
I have Kitchen Aid trash compactor about three years old. It's gotten extremely hard to open the drawer. You
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » Compactor won't open
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 11-19-2007, 03:27 PM
Frank I Frank I is offline
Junior Member
Frank I is on a distinguished road
Default Compactor won't open
I have Kitchen Aid trash compactor about three years old. It's gotten extremely hard to open the drawer. You either have to push down on the pedal relly hard or lift the front up to open. I've replaced the front rollers and pedal but it didn't help. It's easier to open when empty. I get a lot of dirty look's from the wife! HELP!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-10-2008, 01:35 PM
diginorm diginorm is offline
Junior Member
diginorm is on a distinguished road
Default
Same compactor (brand) and problem as Frank. Tried cleaning and lubrication, that didn't help. Seems like if we close the door really hard, it helps sometimes. Almost like it's dropping too far into the recess on the track that holds it closed, and the pedal can't provide enough force to open it.
  #3 (permalink)
Old 01-16-2008, 11:49 AM
Junior Member
Default
I finally did fix the problem, here's how I did it: First make sure the unit is plumb and level using the adjustments in the front. Remove the drawer. Then find two flat-headed screws. Screw them into the frame/floor of the unit as close to the front of the unit as possible about 6" apart. Install the bin/drawer. If the screws drag on the bottom of the bin, remove the bin and grind down the screw heads with a grinder or a file. You might also try banging in the bottom of the bin with a hammer as it may be out of shape from compaction. It worked for me, no more dirty looks! Frank I
  #4 (permalink)
Old 02-04-2008, 09:44 PM
Junior Member
Default
Thanks Frank. About the same time you figured it out I fixed mine, not quite as dramatic:
Pulled the drawer all the way out, cleaned and lubed the wheels. Checked the bottom and found dirt and wear spots where bin was rubbing. Cleaned it thoroughly including the wear spots (steel wool or similar would do). Did the same thorough cleaning of the floor of the unit, making sure to get the wear spots rubbed down. Lube the rails, put the door back in, good as new.
I did check the alignment and it looks good. Just the two spots near the front, probably about where you put the screws in.
No more dirty looks here either!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
how to open power board ibrahimdd Microwave Repair 5 11-15-2007 10:24 PM
Door Locked Open chrisc2007 Washer Repair 1 11-14-2007 07:58 PM
Soap dispenser won't open mnbaird Dishwasher Repair 4 10-25-2007 02:11 AM
Ice maker door won't open hockeydad Refrigerator & Freezer Repair 0 08-07-2007 01:46 PM
Oasis HE - how to open for cleaning? ksevern Washer Repair 1 08-04-2007 09:58 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
