| » ge compactor (2005 model) jammed! |
The problem is the trash ram is pushing down on the edge of the metal of the trash compartment because the door is partially open. The solution is to back-up the ram the the door will close.
To back-up the ram, you will need to pull the compactor out from under your cabinets and unplug it. Turn the compactor on it's side to expose the bottom. There is a plate on the bottom that covers the motor gears. Remove the plate and turn the large gear counter-clockwise to back-up the ram screws (at least this is how it works on my model works). The gears are a little greasy so you may need to add some after messing with the gears. |
| Display Modes | |
| Kitchen aid trash compactor model no.KUCS02FRSS1 | jfaris | Trash Compactor Repair | 2 | 02-14-2009 08:49 AM |
| Thermador Compactor Model TMC30B | RomanS | Trash Compactor Repair | 1 | 11-07-2008 12:50 PM |
| Broan Compactor Jammed | deniseban | Garbage Disposer Repair | 1 | 10-03-2008 04:43 PM |
| Broan compactor jammed | Randy Strickland | Trash Compactor Repair | 1 | 04-06-2008 02:36 PM |
| kenmore compactor jammed | kenmore | Trash Compactor Repair | 1 | 10-25-2007 07:59 AM |
