Discuss
GE Profile GCG1700LH 15" Trash Compactor
 in
Trash Compactor Repair
Installed 2007. When you depress the foot pedal, the pedal remains down and the drawer does not open. I can
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » GE Profile GCG1700LH 15" Trash Compactor
  #1 (permalink)
Old 03-09-2009, 09:26 PM
Junior Member
trashman is on a distinguished road
Default GE Profile GCG1700LH 15" Trash Compactor
Installed 2007. When you depress the foot pedal, the pedal remains down and the drawer does not open. I can open the compactor by manually lifting the bottom of the drawer upward at the pedal base, but the purpose of a compactor is that it should open automatically so you can use the compactor. I've tighten the two screws on the inside on either side of the pedal mechanism (didn't change the situation), had a major company repair person come out and he also tightened the screws (still doesn't work) and, finally, replaced the pedal w/a new one (at repair person's prompting; still doesn't work). So, I'm writing you. The Profile is out of warranty (the major local appliance company we purchased from closed) and it cost $ 619. I'm quite disappointed.Is there something I'm not doing? Is there a certain height from the floor that the pedal should be at? What am I missing about this situation? Thanks for your suggestions/recommendations.
  #2 (permalink)
Old 12-24-2009, 05:33 PM
Junior Member
dannys00 is on a distinguished road
Default Solution for Compactor foot pedal problem
I also found that after 2 years my GE Profile Trash Compactor (purchased in June '07), the pedal was hanging down on the left side. I searched the internet and called GE to no avail.
After a few attempts, I finally solved the problem by removing the screw on the left side and adding a metal "L" bracket, with the bottom of the L flush against the back of the front panel. That way, when you depress the pedal, the screw can't pop out of the metal it's attached to.
Good luck!
Dannys00
  #3 (permalink)
Old 08-13-2011, 08:00 PM
Junior Member
hinesteam is on a distinguished road
Default L Bracket Solution Worked!!!
The L bracket definitely worked. I was having the exact same problem and tried the propose L bracket solutino at 10:30 pm EST. Thank you very much for posting it.
It is a poor design by GE.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
G.E. Profile Trash Compactor Jamison Trash Compactor Repair 4 02-01-2010 08:08 AM
Kitchenaid 18" Trash Compactor Hums nostalgiaguru Trash Compactor Repair 1 10-13-2009 02:58 PM
Kitchen aid 18" trash compactor shawnandv Trash Compactor Repair 2 09-11-2009 09:13 AM
GE Profile Trash Compactor GCG1540F0SS diva_web Trash Compactor Repair 0 12-06-2008 06:09 PM
KitchenAid Trash Compactor foot pedal wont' open the compactor Tony Seaton Trash Compactor Repair 1 08-19-2008 12:03 AM
