Discuss
G E trash compactor
 in
Trash Compactor Repair
The door is open about 2 inches but will not open any further. Cannot close door either. I think my
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » G E trash compactor
  #1 (permalink)
Old 03-05-2009, 11:24 AM
Junior Member
bobbyg is on a distinguished road
Default G E trash compactor
The door is open about 2 inches but will not open any further. Cannot close door either. I think my daughter had stated to run the compactor and then tried to open the door to put one more item in. The compactor is now locked up. Any advice please???
  #2 (permalink)
Old 03-06-2009, 11:30 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Try to push the door in and restart the trash compactor.
gene.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 04-13-2009, 01:28 PM
Junior Member
Kimostrom is on a distinguished road
Default
Wondering if your advise worked for BobbyG as my compactor is stuck about 2" open as well today and was in use when it was opened by mistake!
HELP!
  #4 (permalink)
Old 04-13-2009, 02:18 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
HELP!
Did you try to do it?
__________________
  #5 (permalink)
Old 04-13-2009, 02:56 PM
Junior Member
Default GE Trash Compactor
Yes, the door will not close...stuck in position about 2" from closing and the bin is empty so I know that nothing is clogging it up.
We have a GE Monogram ZCGS150 Model
  #6 (permalink)
Old 04-13-2009, 04:22 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the trash compactor from the cabinet. Put it on its side and remove the bottom cover. Inspect the chain and gears. You can lift the ram up by rotating the main gear.
__________________
  #7 (permalink)
Old 04-13-2009, 05:30 PM
Junior Member
Default
Thank you for the advise....my husband was able to get the door open and reset the switch to get it going again so we're good to go!
  #8 (permalink)
Old 04-13-2009, 06:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad it was that simple.
__________________
  #9 (permalink)
Old 05-23-2009, 12:35 PM
Junior Member
marchboom is on a distinguished road
Default
I have the exact same compactor with the same problem. GE was no help. Followed Gene's instructions (turned the main gear till the ram lifted out of the way of the bin) and the compactor worked again. You saved me some $$$ (service call). Thanks Gene!
  #10 (permalink)
Old 05-23-2009, 08:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Trash Compactor xendau Trash Compactor Repair 1 08-08-2010 10:49 AM
trash compactor justine Trash Compactor Repair 0 09-05-2009 02:47 AM
GE Trash Compactor Jamesmcknight Trash Compactor Repair 3 07-28-2009 06:58 AM
Trash Compactor ljb Trash Compactor Repair 1 05-19-2009 03:43 PM
KitchenAid Trash Compactor foot pedal wont' open the compactor Tony Seaton Trash Compactor Repair 1 08-19-2008 12:03 AM
