| » Jenn air TC507 Trash comp. Stuck in down position |
Remove the trash compactor from the cabinet and put it on its side. Remove the bottom cover and check the chain and the gears. Lift the ram up by manually rotating the gear. Remove the container. Remove the top cover and check the power nuts and power screws. Replace all worn out parts.
Here are the break down diagrams and the parts list for the Jenn Air trash compactor Model TC507B Gene.
__________________
Professional appliance repair in Orange County, California. |
Thanks Gene,
A plastic bag got caught up in one of the screw drives where it threads through the nylon nut attached to the ram. It was a bit of a challenge but hey who doesn't like a challenge from time to time. Again thank you for your help. Ken |
Ken,
You are welcome. I'm glad nothing broke. This is one of most common problems. Use only manufacturer authorized bags to prevent it. Gene.
__________________
So what is different about the factory bags that can prevent this?
When the unit is near full or full, trash seems to go every where when you push the drawer back in and the trash is above the upper edge of the opening. Ken |
__________________
| Display Modes | |
| Lubed Jenn-air Trash compactor as instructed | bobg7 | Trash Compactor Repair | 0 | 02-23-2008 11:10 AM |
| jenn air Trash compactor | bobg7 | Trash Compactor Repair | 4 | 02-03-2008 12:09 PM |
| Jenn-Air trash compactor doesn't compact | nmhiggins | Trash Compactor Repair | 0 | 11-24-2007 12:56 PM |
| jenn air trash compactor sticks | rbern007 | Trash Compactor Repair | 3 | 10-11-2007 11:34 PM |
