Discuss
Whirlpool Tracs Compacter
 in
Trash Compactor Repair
I have a Whirlpool Trash Compactor Model # TC8750. When the compactor reaches the top of the cycle it will thump
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » Whirlpool Tracs Compacter
  #1 (permalink)
Old 02-12-2009, 09:20 AM
Jeff C. Jeff C. is offline
Junior Member
Jeff C. is on a distinguished road
Default Whirlpool Tracs Compacter
I have a Whirlpool Trash Compactor Model # TC8750. When the compactor reaches the top of the cycle it will thump till I hit the off button. What suggestions do you have?
Thanks,
Jeff Cowdrey
  #2 (permalink)
Old 02-12-2009, 06:36 PM
TechnicianBrian's Avatar
TechnicianBrian TechnicianBrian is offline
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
If you open the drawer you will find two screws holding the control panel in place. Remove the screws, then lift up on the panel. Behind the panel is the direction switch that is actuated by an arm attached to the ram. This is what stops the unit at the top. See if the arm is bent on the ram and the switch. The switch has two positions so when you actuate the arm, you should rear two distinct clicks. A multimeter can be used to determine if the switch is working properly, but first verify it is being properly actuated.
__________________
TechnicianBrian
TechnicianBrian.com
AllTechAppliance.com
  #3 (permalink)
Old 02-12-2009, 08:50 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Default
Just to add my 2 cents...
Another cause could be the pushbutton switch if it's stuck in the "start" position. For the right part number we need the end of the model number.
__________________
  #4 (permalink)
Old 02-13-2009, 08:06 PM
Junior Member
Default
Thanks guys works like new. Checks in the mail!!!
  #5 (permalink)
Old 02-14-2009, 07:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
