Discuss
Kitchen Aid trash compactor won't raise
 in
Trash Compactor Repair
Kitchenaid model kucc151gss sticks down when using the "solid pack" compact button. When toggling this compact button off
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » Kitchen Aid trash compactor won't raise
  #1 (permalink)
Old 02-09-2009, 01:35 PM
erics erics is offline
Junior Member
erics is on a distinguished road
Default Kitchen Aid trash compactor won't raise
Kitchenaid model kucc151gss sticks down when using the "solid pack" compact button. When toggling this compact button off to "normal", we just hear a buzzing sound like the motor is stuck in the down/compacted position. We have then just turned the radial switch on the right side to "off" to save the motor.
Is this a motor problem or possibly one of the switches? One more note: the compactor cycles down and up normally when just using the radial dial "start" "on" switch on the right. It just gets stuck in the lowest down position with the "solid pack" button engaged. Please help!
Last edited by erics : 02-09-2009 at 02:32 PM. Reason: I found more info and wanted to be complete.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchen aid 18" trash compactor shawnandv Trash Compactor Repair 2 09-11-2009 10:13 AM
Kitchen aid trash compactor model no.KUCS02FRSS1 jfaris Trash Compactor Repair 2 02-14-2009 09:49 AM
Kenmore compactor ram won't raise texaszinnia Trash Compactor Repair 3 11-09-2008 11:04 PM
KitchenAid Trash Compactor foot pedal wont' open the compactor Tony Seaton Trash Compactor Repair 1 08-19-2008 01:03 AM
Kitchen Aid Trash Compactor Drawer Slides Jim Michalek Trash Compactor Repair 2 03-06-2008 06:11 PM
