| » trash compactor wont run automatically when i turn the rotary switch on |
Model Number: tc507b Brand: Jenn-Air Age: 1 - 5 years
Initial problem: Turned the rotary switch to run and it stayed on run and the compacor went down and came up making the thumping sound till i turned it off manually. Put in a knew rotary switch.
Secondary problem: I need to hold the rotary switch in the on position to get it to compact. It then goes up and starts thumping the top till i release it. Replaced the top directional switch. No change. I am looking at replacing the motor switch next. does this seem like a reasonable next step. Some feed back would be great Normal function turn switch to run not hold it on run. Compactor then compacts trash and returns to the upward starting position automatically. Thanks joe Ads By Google Related Models |
Joe,
Sounds like you are going in the right direction. If it would not help then replace the whole motor and the motor switch can be returned if ordered from Appliance Parts Pros. - The motor switch Part number: AP3117747 - The motor Part number: AP3081024 Here are the breakdown diagrams and Replacement parts for JENN-AIR TC507B COMPACTOR | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Whirlpool Trash Compactor Won't Turn On | mshamby1 | Trash Compactor Repair | 1 | 04-09-2012 12:56 PM |
| Jennair Trash Compactor wont Open | cindyg | Garbage Disposer Repair | 0 | 03-20-2009 06:49 PM |
| KitchenAid Trash Compactor foot pedal wont' open the compactor | Tony Seaton | Trash Compactor Repair | 1 | 08-19-2008 12:03 AM |
| Whirlpool Trash Compactor - Bad Switch | Thomas M> | Trash Compactor Repair | 0 | 04-16-2008 07:26 PM |
| Trash compactor Centrifugal switch | msehome | Trash Compactor Repair | 0 | 10-02-2007 05:44 AM |
