Discuss
kenmore compactor jammed
 in
Trash Compactor Repair
I have a Kenmore trash compactor that will not let me open the door because it's jammed. The door
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » kenmore compactor jammed
  #1 (permalink)
Old 10-20-2007, 07:45 PM
kenmore kenmore is offline
Junior Member
kenmore is on a distinguished road
Default kenmore compactor jammed
I have a Kenmore trash compactor that will not let me open the door because it's jammed. The door has opened enough so that i can see inside but i can't get to anything. there is cabinets built around the compactor so if someone may has a equipment manual link to send to me that would be a great help I think the compactor which is 15 inches is about 20 something yrs old.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-25-2007, 08:59 AM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
See if there is a model number posted inside the storage compartment above the main door. Most likely your compactor was made by Whirlpool, but could also be Broan. Post the model number and I'll get you breakdown diagrams for it.
Typically, when a compactor is jammed and the door cannot be opened, you'd have to pull it out of the cabinet, unplug the power cord and disassemble from either top or back, depending on the brand. If it's Whirlpool, remove the top panel, then power nuts, then the ram - from there you can remove the door and whatever foreign objects that caused the jam.
Hope this helps.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Compactor no longer a smashing success tjtroy Trash Compactor Repair 0 10-18-2007 05:52 AM
jenn air trash compactor sticks rbern007 Trash Compactor Repair 3 10-11-2007 11:34 PM
Garbage Compactor flaumbetty Trash Compactor Repair 3 10-04-2007 03:02 PM
Trash compactor Centrifugal switch msehome Trash Compactor Repair 0 10-02-2007 06:44 AM
Trash Compactor MValley General Talk 1 08-17-2007 09:25 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
