Discuss
Compactor no longer a smashing success
 in
Trash Compactor Repair
I have an older TAPPAN trash compactor M/N 52-2434-10-02 that has stopped working. The ram is
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » Compactor no longer a smashing success
  #1 (permalink)
Old 10-18-2007, 05:52 AM
tjtroy tjtroy is offline
Junior Member
tjtroy is on a distinguished road
Default Compactor no longer a smashing success
I have an older TAPPAN trash compactor M/N 52-2434-10-02 that has stopped working. The ram is in the top, or home position. When I turn the start switch, I can hear the motor "hum" but the ram does not move. If I disconnect the power and manually run the ram down, then re-apply power, the motor starts and returns the ram to the the home position. I see from the schematic on the unit that there are 2 limit switches, plus another switch that control the up/down functions by switching the forward/reverse coils in the motor. I am only assuming that since the motor runs to return the ram to the home position, that it is good. I suspect possibly the upper limit switch may be the cause, but I really need some help. Is anyone familar with this model?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Garbage Compactor flaumbetty Trash Compactor Repair 3 10-04-2007 03:02 PM
Oven takes longer to preheat than before graciesmom Oven Repair (including Ranges and Cooktops) 0 09-08-2007 09:53 AM
Trash Compactor MValley General Talk 1 08-17-2007 09:25 AM
Dryer no longer runs. scott_lange Dryer Repair 2 08-09-2007 11:38 PM
Freezer no longer cold enough clowder64 Refrigerator & Freezer Repair 1 07-25-2007 04:21 PM
