| » Compactor no longer a smashing success |
I have an older TAPPAN trash compactor M/N 52-2434-10-02 that has stopped working. The ram is in the top, or home position. When I turn the start switch, I can hear the motor "hum" but the ram does not move. If I disconnect the power and manually run the ram down, then re-apply power, the motor starts and returns the ram to the the home position. I see from the schematic on the unit that there are 2 limit switches, plus another switch that control the up/down functions by switching the forward/reverse coils in the motor. I am only assuming that since the motor runs to return the ram to the home position, that it is good. I suspect possibly the upper limit switch may be the cause, but I really need some help. Is anyone familar with this model?
| Display Modes | |
| Garbage Compactor | flaumbetty | Trash Compactor Repair | 3 | 10-04-2007 03:02 PM |
| Oven takes longer to preheat than before | graciesmom | Oven Repair (including Ranges and Cooktops) | 0 | 09-08-2007 09:53 AM |
| Trash Compactor | MValley | General Talk | 1 | 08-17-2007 09:25 AM |
| Dryer no longer runs. | scott_lange | Dryer Repair | 2 | 08-09-2007 11:38 PM |
| Freezer no longer cold enough | clowder64 | Refrigerator & Freezer Repair | 1 | 07-25-2007 04:21 PM |
