Discuss
jenn air trash compactor sticks
 in
Trash Compactor Repair
sticks on last 2 inches of closing, does not spring open. have cleaned and oiled. can you help? thanks rob
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » jenn air trash compactor sticks
  #1 (permalink)
Old 10-08-2007, 12:49 PM
rbern007 rbern007 is offline
Junior Member
rbern007 is on a distinguished road
Default jenn air trash compactor sticks
can you help?
thanks
rob
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-08-2007, 03:22 PM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Post the compactor model number. Should be on a tag inside the storage compartment above the drawer.
  #3 (permalink)
Old 10-08-2007, 08:39 PM
Junior Member
model TC507Q0
thanks
  #4 (permalink)
Old 10-11-2007, 11:34 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi rbern007
The first thing I would check is the lock on the right side of the container. See if everything is in place.
The second thing I would check if the ram is in the upper position. You also can pull the t/c out of the cabinet, remove the top cover and check the ram position from the top.
- Here are the break down diagrams for the Jenn Air trash compactor Model TC507Q
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn-air 88370 Schematics claude_123 Oven Repair (including Ranges and Cooktops) 3 10-19-2008 09:40 AM
Garbage Compactor flaumbetty Trash Compactor Repair 3 10-04-2007 03:02 PM
Trash compactor Centrifugal switch msehome Trash Compactor Repair 0 10-02-2007 06:44 AM
Jenn-Air Wiring ezra710 Oven Repair (including Ranges and Cooktops) 0 09-20-2007 09:39 AM
Trash Compactor MValley General Talk 1 08-17-2007 09:25 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
