| » Thermador broken start switch |
Model Number: WCC22 Brand: Thermador Age: More than 10 years
I bought a house with an older Thermador Waste King under counter trash compactor. The seller said it did not work. The operating switch is a rotary removable key style with three positions-- off..on..start. If I hold the switch to the start position the unit operates and runs through the cycle. If I let go of the key, the unit stops at whatever point in the cycle the ram is in. Do I understand that typically you turn these switches to start and let go and it automatically runs through the cycle and shuts itself off? I pulled the switch and it has a cam on the back side the turns with the turning of the key and engages a door lock pin. The number on the switch is 639-852023-1. It seems to me that the switch is broken but I have no part number other than the above number that is printed on the switch body. It looks like the cam comes off and would be installed on a replacement switch. Is this switch mafunctioning and if so is a replacement or equivalent available?
Thanks in advance Rick in CT Ads By Google Related Models |
| Display Modes | |
| Thermador Glass Electric Cooktop broken | schlosscat | Oven Repair (including Ranges and Cooktops) | 0 | 05-20-2010 04:32 AM |
| Thermador Range Broken Venturi | Eugene Osentoski | Oven Repair (including Ranges and Cooktops) | 0 | 03-08-2010 06:04 AM |
| Thermador Range Hood Intensive Speed Broken | whizwith | Oven Repair (including Ranges and Cooktops) | 0 | 10-06-2009 09:35 AM |
| broken start switch | shmba024 | Dryer Repair | 2 | 08-10-2009 04:39 PM |
| How to exchange broken burner valve on Thermador Range | patrikf | Oven Repair (including Ranges and Cooktops) | 2 | 05-21-2009 05:44 AM |
