Discuss
Kitchen Aid trash compactor will not stop
 in
Trash Compactor Repair
My Kitchen aid trash compactor would not shut off, had to trip circuit braeker. the door would not open because
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » Kitchen Aid trash compactor will not stop
  #1 (permalink)
Old 10-28-2010, 08:45 AM
Junior Member
Dawg Fan is on a distinguished road
Default Kitchen Aid trash compactor will not stop
Brand: Kitchen Aid   Age: 1 - 5 years
My Kitchen aid trash compactor would not shut off, had to trip circuit braeker. the door would not open because the ram was down. Took bottom panel off and found the 5" white gear broken in half. I manually turned the shaft that raises the ram to open the door. When I tried to test the motor it would hum and turn the gear on the shaft very slowly, less than 1 turn until the motor turned off.
Is the mote burned out? Is a switch bad?
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchen Aid trash compactor won't raise erics Trash Compactor Repair 1 01-17-2011 09:56 AM
Kemore Trash Compactor Won't Stop Micky-D Trash Compactor Repair 4 01-08-2010 04:23 PM
Kitchen Aid trash compactor Tennessee Trash Compactor Repair 0 11-02-2009 08:53 AM
Kitchen aid 18" trash compactor shawnandv Trash Compactor Repair 2 09-11-2009 09:13 AM
Kitchen Aid trash compactor shuts off Donald Marden Trash Compactor Repair 0 08-27-2009 07:05 AM
