Discuss
Kenmore 665.13619100
 in
Trash Compactor Repair
Compactor has two modes, normal and extra pack. Usually you turn the dial, let go and the ram does it'
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » Kenmore 665.13619100
  #1 (permalink)
Old 08-18-2008, 06:51 PM
mitcheal mitcheal is offline
Junior Member
mitcheal is on a distinguished road
Default Kenmore 665.13619100
Compactor has two modes, normal and extra pack. Usually you turn the dial, let go and the ram does it's thing. now, in normal pack, i have to hold the dial to get it to go down and up. in extra pack, i turn the dial and let go as normal and everything is great. normally to get the ram back up after an extra pack, you hit the normal button and it comes up. now, i hit the button and nothing. i have to turn the dial and hold it until the ram is up. i think it's the dial, but it could be the buttons. any ideas?
thanks,
mitch.
  #2 (permalink)
Old 08-19-2008, 04:58 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Hi Mitch,
Check the top limit switch, the normal & extra pack switch and the motor centrifugal switch as described in the tech sheets. Post the results.
__________________
  #3 (permalink)
Old 08-27-2008, 05:43 PM
Junior Member
Default
Gene, i'm mechanically inclined, not really electronically. I took a look at the tech sheets and got confused. Any pointers?
We just had a baby, so money is tight. we might have to live with hloding the dial for a month or two.. will that cause any more issues?
thanks,
mitch.
  #4 (permalink)
Old 08-27-2008, 06:07 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Mitch,
The worst thing could happen is burned motor and nobody knows how soon it can be. In that case you are looking about $170 (if you'll do it yourself).
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
