Discuss
GE Trash Compactor hums
 in
Trash Compactor Repair
Originally Posted by Russellcdodd When i try ro run my compactor, it just hums. Twice, I have taken the outside
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » GE Trash Compactor hums
  #21 (permalink)
Old 11-17-2015, 02:35 AM
Junior Member
Jessica881206 is on a distinguished road
Default
Quote:
Originally Posted by Russellcdodd View Post
When i try ro run my compactor, it just hums. Twice, I have taken the outside shell off the compactor, taped the switches, and the compactor ran fine. I put the shell back on and for several weeks it continued to run fine. Then all the sudden it just hums again. I have confirmed there is nothing stuck around he ram.
I know little about your problems, however, I recommend you to refer to ManualBirds - Download Free PDF Manuals & Guides Online, which is a free site for thousands of PDF manuals, guides and handbooks, hope Manualbirds can do you a great favor!
  #22 (permalink)
Old 04-18-2016, 07:15 AM
Junior Member
ZiptheDoc is on a distinguished road
Default Ge Profile Compactor Hums
Greetings all, this issue, which can be fixed with a new motor, is actually a problem with the motor end switch. This switch is used in the start winding circuit for both up and down. If the switch fails in the open position then the motor will not start and it will hum as only the run winding is energized. Removing the top end bell of the motor will expose the end switch and you will see it is burned or black. It can be removed and cleaned, check that it measures closed, about .3 ohms, before you reinstall it. Re check the connection again before testing the compactor. I have not been able to find a replacement end switch as of this posting as I feel that the cost of a motor is a bit much for a bad end switch I will keep looking
Regards Doc'
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Trash Compactor xendau Trash Compactor Repair 1 08-08-2010 11:49 AM
Trash Master Hums Sunnie Trash Compactor Repair 1 03-23-2010 11:05 AM
Kitchenaid 18" Trash Compactor Hums nostalgiaguru Trash Compactor Repair 1 10-13-2009 03:58 PM
trash compactor oxoboxo2000 Trash Compactor Repair 0 02-25-2009 11:31 AM
KitchenAid Trash Compactor foot pedal wont' open the compactor Tony Seaton Trash Compactor Repair 1 08-19-2008 01:03 AM
