Discuss
No water from the door dispensor on a GE
 in
Refrigerator & Freezer Repair
I have a GE Refrigerator that has quit dispensing water out of the door. It appears that I still have
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » No water from the door dispensor on a GE
  #1 (permalink)
Old 07-18-2008, 03:58 PM
rhall42 rhall42 is offline
Junior Member
rhall42 is on a distinguished road
Default No water from the door dispensor on a GE
Model Number: GSS20IEMBWW   Brand: GE   Age: 5 - 10 years
I have a GE Refrigerator that has quit dispensing water out of the door. It appears that I still have water to the ice maker. Could my problem be that the water valve assembly has gone bad?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-18-2008, 04:09 PM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Take off the grill (kickplate) at the bottom of the doors. under the freezer door you will see a waterline that is connected to a union. Disconnect the water line from that union connector by pushing in on the white ring and pulling on the hose. water will come out of the freezer door side line, but just a little bit. Now make sure the freezer door is closed and push the arm in like your getting a glass of water, if water comes out the hose you disconnected, then the water line in the door is frozen, if no water comes out when calling for water, then we will procede....keep me posted
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 07-18-2008, 05:35 PM
Junior Member
Default
Quote:
I checked out the valve and it was good. I removed the front kick panel and disconnected the union and discovered ice in the line. I will have to replace the union because when I put it back together it leaked, but that fixed my problem. Thanks for your help.
  #4 (permalink)
Old 11-03-2008, 10:26 AM
cdadek cdadek is offline
Junior Member
cdadek is on a distinguished road
Default GE Refrigerator Model #GSL25JFTA Water Dispenser Not Working
I have a ge refrigerator model #GSL25JFTA. It was purchased in 2006. The Water Dispenser does not work sometimes. The Ice Maker is working and dispensing.
I took off the front grill at the bottom of the refrigerator and disconnected the water line. No water came out of the water dispenser.
Now what? Other suggestions?
Thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE GSL25JFTA Fridge water dispensor quit, ice maker still works jcasaccio Refrigerator & Freezer Repair 0 06-29-2008 10:19 AM
Water Dispensor rco224 Refrigerator & Freezer Repair 1 06-17-2008 01:47 PM
Water dispensor will not allow water out tsmith Refrigerator & Freezer Repair 2 12-30-2007 04:15 PM
Water leaking under door...need to know how to remove door & replace seal edbolliera Dishwasher Repair 1 11-27-2007 04:42 AM
Water Dispensor Dripping PLMSMH Refrigerator & Freezer Repair 4 11-26-2007 09:30 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
