Discuss
ice trap door
 in
Refrigerator & Freezer Repair
Hi there my problem is that the ice trap door won't open when you try to get ice it
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » ice trap door
  #1 (permalink)
Old 07-17-2008, 03:59 AM
genuine genuine is offline
Junior Member
genuine is on a distinguished road
Default ice trap door
Model Number: gss201emb ww   Brand: GE   Age: 1 - 5 years
Hi there my problem is that the ice trap door won't open when you try to get ice it falls into door from ice bucket but flap will not open ..... any help would be appreciated
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-17-2008, 03:02 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Did you hear a click when depressed the dispenser cradle?
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 07-17-2008, 05:25 PM
Junior Member
Default
yes there is a click noise but no movement on trap door
  #4 (permalink)
Old 07-17-2008, 06:15 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You have to take apart the ice & water dispenser on the freezer door to find out what is wrong with the chute door.
Use a small flat screwdriver to unlock the tabs at the bottom of the control panel. Slide the bottom out and down.
Disconnect the wiring harness connectors.
Remove the four Phillips screws in the door dispenser housing.
Slide out the housing and disconnect the target switch and dispenser light connectors.
Diagnose the problem and find needed parts, using the reference numbers from the break down diagram.
Here are the break down diagrams for the GE refrigerator Model GSS20IEMBWW
__________________
  #5 (permalink)
Old 07-18-2008, 02:17 PM
Junior Member
Default
thanks for your help it turned out to be the solinoid for the trap
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
something in lint trap lesliekim Dryer Repair 3 05-08-2008 07:21 PM
My oven door won't stay shut and the light stays on. The door is loose. Vanise Oven Repair (including Ranges and Cooktops) 2 03-24-2008 12:36 PM
How do I remove manifold trap from tub? Sensible Washer Repair 2 02-17-2008 10:50 AM
Water leaking under door...need to know how to remove door & replace seal edbolliera Dishwasher Repair 1 11-27-2007 04:42 AM
My Oven Door Latch Won't unlock so the door won"t close Victorine Ravenell Oven Repair (including Ranges and Cooktops) 1 11-14-2007 11:40 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
