Discuss
icemaker water freezes in feed tube
 in
Refrigerator & Freezer Repair
Hello, the water going to the icemaker freezes in the feed tube and does not make ice. Thank you Mark
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » icemaker water freezes in feed tube
  #1 (permalink)
Old 07-16-2008, 07:39 PM
mstrauel mstrauel is offline
Junior Member
mstrauel is on a distinguished road
Default icemaker water freezes in feed tube
Model Number: gd25dfxfb01   Brand: Whirlpool   Age: 5 - 10 years
Hello,
Thank you
Mark
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-16-2008, 10:03 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Mark,
Most likely the problem is a bad water inlet valve on the back of the refrigerator.
- The part number for the water inlet valve is AP3160649
Here are the break down diagrams for the Whirlpool refrigerator Model GD25DFXFB01
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 07-18-2008, 01:31 PM
Junior Member
Default
Hello Gene,
Thanks for the advice. Can you tell me the reason behind, how a broken water inlet valve causes the water to freeze in the inlet tube.
thank you
Mark
  #4 (permalink)
Old 07-18-2008, 02:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Because it did not shut water off when it should. Water keeps running slowly and freezes up in the tube.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Icemaker Tube freezes the water then leaks glennb100 Refrigerator & Freezer Repair 0 07-11-2008 04:32 PM
Water Thawing Then Freezes???? In Fridge??? TeeTee Refrigerator & Freezer Repair 7 06-10-2008 11:24 AM
Copper water inlet tube discontinued, now what? jmf Refrigerator & Freezer Repair 3 03-20-2008 06:31 AM
water tube connector justone Refrigerator & Freezer Repair 1 12-04-2007 12:22 PM
ice maker - water freezing in tube lannym Refrigerator & Freezer Repair 1 12-01-2007 04:07 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
