Discuss
Kitchenaid Icemaker Issues- Free standing
 in
Refrigerator & Freezer Repair
I returned from a trip to see that my ice maker was only about 1/2 full, which is not normal.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kitchenaid Icemaker Issues- Free standing
  #1 (permalink)
Old 07-16-2008, 01:13 PM
Junior Member
no1hog is on a distinguished road
Default Kitchenaid Icemaker Issues- Free standing
Model Number: kuia15plls2   Brand: Kitchen Aid   Age: 1 - 5 years
I returned from a trip to see that my ice maker was only about 1/2 full, which is not normal. The ice seemed to be slowly melting. I turned the unit off and cleaned it as normal. When I have turned it back on, it doesn't make ice. I cleaned the condenser, which was not dirty to speak of, and have monitored the timing of functions such as fan running, water input, water recycling (internal pump operations), grid heat, etc. Everything appears to be functioning at the proper time. However, the evaporator is not cooling. I suspected the evaporator thermistor, which I removed and retried the unit without it, because the literature with the ice maker said it would operate in a time mode (rather than temperature mode) if the evaporator thermistor was open or not present. The unit continues not to cool down the evaporator. I am wondering if the solenoid reversing valve or coil is bad. Does this make sense? Also, can I change the solenoid coil without disrupting the sealed refrigerant? My plans are tentatively to order a new solenoid coil, a new evaporator thermistor, and a new bin (ice control) thermistor and replace them all. Does this make sense? Thank you.
Update: I have measured the resistance of the coil for the reversing solenoid and it reads 385 ohms as shown on the spec sheet. I cooled and heated the two thermistors and they both reacted with the resistance changing in the right direction depending on heat or cool being applied, but I didn't have a means to tell if they were at the spec'd temperatures when I read their resistance. Both of them seemed to be in the ball park.
Second Update: I have followed the diagnotics that run at the beginning of the clean cycle and have solid light during the bin thermistor and evaporator thermistor periods, in fact the light is solid as long as I let the clean cycle run. Following the 11 seconds that are used to diagnose the thermistors, the water valve, condenser fan, hot gas solenoid, recirculating pump and compressor each go on (I can hear them) for 5 seconds each in accordance with the service sheet. The fan and compressor run, but I never feel warm air coming out of the unit. That is true in the clean cycle and on cycle. Also, when I touch the evaporator plate and tubes underneath it, it never gets cold on either cycle, even though the compressor is running. I also disconnected the hot gas solenoid while in the clean cycle and clearly could hear a clip when attached and detached. I am about out of things I think I can do. Any ideas?
Anybody out there that can give me a path forward?
Ads By Google
Related Models
Whirlpool KUIA15PLLS2 Ice Cube Maker
Whirlpool KUIA15PLLS3 Ice Cube Maker
Whirlpool KUIA15PLLS4 Ice Cube Maker
Whirlpool KUIA15PLLS5 Ice Cube Maker
Whirlpool KUIA15PRLS0 Ice Cube Maker
Whirlpool KUIA15PRLS1 Ice Cube Maker
Whirlpool KUIA15PRLS11 Ice Cube Maker
Whirlpool KUIA15PRLS2 Ice Cube Maker
Whirlpool KUIA15PRLS3 Ice Cube Maker
Whirlpool KUIA15PRLS4 Ice Cube Maker
Whirlpool KUIA15PRLS5 Ice Cube Maker
Whirlpool KUIA18NNJS11 Ice Cube Maker
Whirlpool KUIA18NNJS3 Ice Cube Maker
Whirlpool KUIA18NNJS4 Ice Cube Maker
Whirlpool KUIA18NNJS5 Ice Cube Maker
Whirlpool KUIA18NNJS6 Ice Cube Maker
Whirlpool KUIA18NNJS7 Ice Cube Maker
Whirlpool KUIA18NNJS8 Ice Cube Maker
Whirlpool KUIA18PNLS0 Ice Cube Maker
Whirlpool KUIA18PNLS1 Ice Cube Maker
Whirlpool KUIA18PNLS11 Ice Cube Maker
Whirlpool KUIA18PNLS2 Ice Cube Maker
Whirlpool KUIA18PNLS3 Ice Cube Maker
Whirlpool KUIA18PNLS4 Ice Cube Maker
Whirlpool KUIA18PNLS5 Ice Cube Maker
Whirlpool KUIC15NLSS0 Ice Cube Maker
Whirlpool KUIC15NLTS0 Ice Cube Maker
Whirlpool KUIC15NLTS1 Ice Cube Maker
Whirlpool KUIC15NRSS0 Ice Cube Maker
Whirlpool KUIC15NRTS0 Ice Cube Maker
Whirlpool KUIC15NRTS1 Ice Cube Maker
Whirlpool KUIC15PLTS0 Ice Cube Maker
Whirlpool KUIC15PLTS1 Ice Cube Maker
Whirlpool KUIC15PRTS0 Ice Cube Maker
Whirlpool KUIC15PRTS1 Ice Cube Maker
Whirlpool KUIC18NNSS0 Ice Cube Maker
Whirlpool KUIC18NNTS0 Ice Cube Maker
Whirlpool KUIC18NNTS1 Ice Cube Maker
Whirlpool KUIC18PNTS0 Ice Cube Maker
Whirlpool KUIC18PNTS1 Ice Cube Maker
Whirlpool KUIO15NNLS Ice Cube Maker
Whirlpool KUIS155HBL0
Whirlpool KUIS155HBL1
Whirlpool KUIS155HBL2
Whirlpool KUIS155HBL3
Whirlpool KUIS155HBL4 Ice Cube Maker
Whirlpool KUIS155HBS0
Whirlpool KUIS155HBS1
Whirlpool KUIS155HBS2
Whirlpool KUIS155HBS3
Whirlpool KUIS155HBS4 Ice Cube Maker
Whirlpool KUIS155HBT0
Whirlpool KUIS155HBT1
Whirlpool KUIS155HBT2
Whirlpool KUIS155HBT3
Whirlpool KUIS155HBT4 Ice Cube Maker
Whirlpool KUIS155HLS0
Whirlpool KUIS155HLS2
Whirlpool KUIS155HLS3
Whirlpool KUIS155HLS4 Ice Cube Maker
Whirlpool KUIS155HPB0
Whirlpool KUIS155HPB2
Whirlpool KUIS155HPB3
Whirlpool KUIS155HPB4 Ice Cube Maker
Whirlpool KUIS155HPW0
Whirlpool KUIS155HPW2
Whirlpool KUIS155HPW3
Whirlpool KUIS155HPW4 Ice Cube Maker
Whirlpool KUIS155HRS0
Whirlpool KUIS155HRS2
Whirlpool KUIS155HRS3
Whirlpool KUIS155HRS4 Ice Cube Maker
Whirlpool KUIS155HWH0
Whirlpool KUIS155HWH1
Whirlpool KUIS155HWH2
Whirlpool KUIS155HWH3
Whirlpool KUIS155HWH4 Ice Cube Maker
Whirlpool KUIS15NRHB4 Ice Cube Maker
Whirlpool KUIS15NRHB5 Ice Cube Maker
Whirlpool KUIS15NRHB6 Ice Cube Maker
Whirlpool KUIS15NRHB7 Ice Cube Maker
Whirlpool KUIS15NRHB8 Ice Cube Maker
Whirlpool KUIS15NRHB9 Ice Cube Maker
Whirlpool KUIS15NRHS4 Ice Cube Maker
Whirlpool KUIS15NRHS5 Ice Cube Maker
Whirlpool KUIS15NRHS6 Ice Cube Maker
Whirlpool KUIS15NRHS7 Ice Cube Maker
Whirlpool KUIS15NRHS8 Ice Cube Maker
Whirlpool KUIS15NRHS9 Ice Cube Maker
Whirlpool KUIS15NRHT4 Ice Cube Maker
Whirlpool KUIS15NRHT5 Ice Cube Maker
Whirlpool KUIS15NRHT6 Ice Cube Maker
Whirlpool KUIS15NRHT7 Ice Cube Maker
Whirlpool KUIS15NRHT8 Ice Cube Maker
Whirlpool KUIS15NRHT9 Ice Cube Maker
Whirlpool KUIS15NRHW4 Ice Cube Maker
Whirlpool KUIS15NRHW5 Ice Cube Maker
Whirlpool KUIS15NRHW6 Ice Cube Maker
Whirlpool KUIS15NRHW7 Ice Cube Maker
Whirlpool KUIS15NRHW8 Ice Cube Maker
Whirlpool KUIS15NRHW9 Ice Cube Maker
Whirlpool KUIS15NRTB1 Ice Cube Maker
Whirlpool KUIS15NRTBO Ice Cube Maker
Whirlpool KUIS15NRTS0 Ice Cube Maker
Whirlpool KUIS15NRTS1 Ice Cube Maker
Whirlpool KUIS15NRTT0 Ice Cube Maker
Whirlpool KUIS15NRTT1 Ice Cube Maker
Whirlpool KUIS15NRTW0 Ice Cube Maker
Whirlpool KUIS15NRTW1 Ice Cube Maker
Whirlpool KUIS15PRHB4 Ice Cube Maker
Whirlpool KUIS15PRHB5 Ice Cube Maker
Whirlpool KUIS15PRHB6 Ice Cube Maker
Whirlpool KUIS15PRHB7 Ice Cube Maker
Whirlpool KUIS15PRHB8 Ice Cube Maker
Whirlpool KUIS15PRHW4 Ice Cube Maker
Whirlpool KUIS15PRHW5 Ice Cube Maker
Whirlpool KUIS15PRHW6 Ice Cube Maker
Whirlpool KUIS15PRHW7 Ice Cube Maker
Whirlpool KUIS15PRHW8 Ice Cube Maker
Whirlpool KUIS185DAL0
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Icemaker Free Standing sdman Refrigerator & Freezer Repair 0 08-19-2009 05:13 PM
kitchenaid free standing gas rang doesnt heat dream4fish Oven Repair (including Ranges and Cooktops) 0 04-15-2009 04:42 PM
Kitchenaid Free Standing Ice Make Atlas Refrigerator & Freezer Repair 0 03-01-2009 08:36 AM
Kitchenaid Free Standing Ice Maker marciabishop Refrigerator & Freezer Repair 10 11-17-2008 08:09 AM
Kitchenaid Free Standing Ice Maker marciabishop Refrigerator & Freezer Repair 0 11-10-2008 08:37 PM
