The ice maker on my G.E. Refridgerator Model #TFX25ZRYDAA is not working. It makes ice, but the "corkscrew" that drops/pushes the ice does not work. We have replaced the motor and the solenoid, but they were not the problem. We have checked with a tester and made sure that all electricle is getting juice an working properly. The only other thing we can think of is the possibility of a bad switch - either the one that is pushed to dispense the ice, or the lever that is moved back and forth to get water/cubes/crushed. Do you have any ideas that will help?
