Leaks and doesn't make ice cubes
Brand: Amana Age: 1 - 5 years
Fridge is 4 years old. Freezer on bottom. Ice cube maker and tray on left in freezer and water dispenser on left inside fridge.
The ice cube maker stopped filling with water and dumping cubes into the tray at the same time the fridge started leaking on the bottom...yet the water dispenser above in fridge works fine and the copper water supply tube into back of fridge seems fine
Yes, freezer doesn't make cubes even with metal arm in proper position.
Ideas ?
Ads By Google
