Discuss
No water from door
 in
Refrigerator & Freezer Repair
I have a GE side by side 21 cu ft refrigerator and the ice maker works but I can not
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » No water from door
  #1 (permalink)
Old 07-15-2008, 09:09 AM
EBDCEH EBDCEH is offline
Junior Member
EBDCEH is on a distinguished road
Default No water from door
Model Number: GSH25KGMBWW   Brand: GE   Age: 5 - 10 years
I have a GE side by side 21 cu ft refrigerator and the ice maker works but I can not get water from the door. I have taken the water valve off and tried to clean the filter but could not locate it on the water valve. I also by passed the water filter inside the refrigerator and still no water. I have turned down the temperature on the refrigerator side to 3 and still nothing. Has anyone else had this problem. Would appreciate any assistance in fixing the problem.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-16-2008, 01:59 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Disconnect the water line connector (#80 on the break down diagram) and check for water coming out under pressure while the dispenser calls for drinking water.
Post the results.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 07-16-2008, 05:27 PM
Junior Member
Do you just pull the tubing off one of the ends of part eighty?
Thanks for you reply
  #4 (permalink)
Old 07-16-2008, 05:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Push in the center ring then pull the tube out.
__________________
  #5 (permalink)
Old 07-16-2008, 05:39 PM
Junior Member
Default
When I took off the left side water came out, (maybe from the icemaker??) when I removed the right side and pressed pressed for water nothing came out on the side
  #6 (permalink)
Old 07-16-2008, 10:18 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check if the water tank in the fresh food compartment (behind the crisper) is not frozen.
Check if 120VAC is coming to the water valve solenoid while the dispenser calls for drinking water.
__________________
  #7 (permalink)
Old 07-18-2008, 05:18 PM
Junior Member
Default
Gene,
I'm sorry it took so long to get back to you, it looks like the tank behind the fresh food compartment is frozen, any suggestion on how to un-thaw the tank? You have beed a great help and I learned alot about refrigerator trouble shooting!!
  #8 (permalink)
Old 07-18-2008, 06:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You can try to use a hair dryer, but be careful not to melt the tank and/or plastic tubes. Check the temperature in the refrigerator.
__________________
  #9 (permalink)
Old 07-18-2008, 06:47 PM
Junior Member
Default
I thought that is was frozen, but I guess it was'nt. I can see water in the top line of the tank I just don't think there is any pressure pushing it to the tank. I tried switching the water line off the water value but they are two different sizes. Also tried switching the wire plug in to the water value but you can't do that either (different types) I'm thinking it might me the water valve. I don't have any way of testing the volts on the valve. Thanks again for all your help (you are great for trying to help)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
no water from door Pekelady Refrigerator & Freezer Repair 0 06-10-2008 08:12 AM
No water thru the door pjzeke Refrigerator & Freezer Repair 1 03-17-2008 09:24 PM
Ice maker will not draw water but water in door works normally kg1okc Refrigerator & Freezer Repair 3 01-26-2008 03:57 PM
No water on door pjboutin Refrigerator & Freezer Repair 5 12-16-2007 03:33 PM
Water leaking under door...need to know how to remove door & replace seal edbolliera Dishwasher Repair 1 11-27-2007 04:42 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
