I have a Kitchen Aid Ice Maker and the pump is not recirculating the water in the pan. It does not circulate for either the rinse cycle or to pump water across the freezer plate. Can I assume it is the pump motor or can it be something else.
Since it will not recirculate, I cannot run a clean cycle but it is only 3 years old.
Is there a way to test the pump motor before I purchase a new one?
