| » Whirlpool side by side not making ice |
Model Number: GS5SHAXLN00 Brand: Whirlpool Age: 1 - 5 years
After I shut off water to make another household repair the water to fridge was off for a day too. After returning the water supply the ice maker does not work. The water in the door works fine. I unplugged fridge for a while, checked supply tube to tray for blockage, checked water valve ops (OK), rotating tray arms seem to work. (They in different spot than before)
I checked the water valve by switching the flat plugs around and pressing the water paddle in the door. Water everywhere on floor. Problem seems to be no water filling tray. I'm not hearing the fill valves operate like I used too. Why would shutting off the water cause a problem? Thanks, Nuuch ![]() |
Quote:
Looks like the problem is a broken plastic tube for the ice maker water line. Pull the fridge out of the wall and check the plastic tube (1/4 " diameter) on the back. Good luck. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Gene,
Thanks for for the reply but I think there was a miscommunication. When I said the water went on the floor that was because I had disconnected the water tube for the ice maker at the valve and had someone push the water paddle in the door to energize the plug. So the ice maker has sat all night, no ice. The tray filled with a little water but that's it. Should the ice ejecting fingers be in the middle of the tray surrounded by ice? I thought they stayed out, then rotated the ice out of the tray when needed. ![]() |
Hi nuuch
Yes, looks like it was a miscommunication. According to your last post, most likely the problem is the ice maker itself. The ice cube ejector should rest at two o'clock position, not in the middle of the tray. in such situation I would replace the ice maker. - The part number for the new ice maker AP3777826 Good luck. Gene.
__________________
| Display Modes | |
| Freezer side works but not refridg side | atlanta404 | Refrigerator & Freezer Repair | 4 | 05-22-2008 06:24 PM |
| side by side whirlpool water wont come out | aduke | Refrigerator & Freezer Repair | 6 | 01-01-2008 05:40 PM |
| ice auger stopped working in GE side-by-side | tmouncer1 | Refrigerator & Freezer Repair | 5 | 10-24-2007 12:39 PM |
| Amana Side by Side Refrigerator Freezer MFG. P1317202WE | josephbowles@earthlink.ne | Refrigerator & Freezer Repair | 0 | 08-10-2007 06:38 PM |
| Side by Side freezer coil iceing over | bksbjmds8 | Refrigerator & Freezer Repair | 2 | 07-25-2007 01:27 PM |
