| » Water won't stop to icemaker |
Model Number: 363.9701711 Brand: Kenmore Age: 5 - 10 years
I have a Kenmore 363.9701711 which is made by GE. Originally I was getting no water to the ice maker. I replaced the water inlet valve. After that water was going to the icemaker but would not shut off. I replaced the ice maker thinking that may be the problem. Still water will not shut off to the ice maker. Any further help would be appreciated.
I just replaced the inlet water valve and that did not solve my problem.
I was thinking it was the timer and was cotemplating of replacing the ice maker. sounds like that did not solve your problem. Any help would be greatly appreciated. my timer doesn't seem to be turning inside the freezer |
Quote:
Would the water shut off if you turn off the ice maker? Would the water shut off if you remove the wires from the water inlet valve? Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
What was the original problem? Which timer did you mean? Gene.
__________________
The new ice maker is Replacement Ice Maker Kit for GE Refrigerator/Freezers (RIM300).
Actually when I dissconnected wires from the inlet valve the water still runs to the ice maker. At no time is it a stream of water, the water runs slow almost a fast drip. |
Quote:
- The water inlet valve Part number: AP3189335 Gene.
__________________
I do not see anything else what could cause it.
__________________
| Display Modes | |
| Kenmore: Water doesn't stop flowing from door dispenser and icemaker fills w/o stoppi | nyseguy | Refrigerator & Freezer Repair | 1 | 04-21-2010 01:36 PM |
| The water dispenser leaks continually, had to cut the water off to stop it | Willie Jones | Refrigerator & Freezer Repair | 1 | 07-12-2009 06:28 PM |
| Kitchenaid Icemaker Won't Stop Cleaning | DAMON ROY | Refrigerator & Freezer Repair | 0 | 05-21-2009 05:08 PM |
| Icemaker does not stop running | golfpro1 | Refrigerator & Freezer Repair | 5 | 05-16-2009 05:53 PM |
| IceMaker does not stop making Ice | sangeet | Refrigerator & Freezer Repair | 0 | 04-15-2009 12:13 PM |
