Hi - I have a 2.5 year old Magic Chef under counter beverage center. It is one of the ones with 2 doors/zones and each zone has its own thermostat.
What is happening is that one side is cooling way less than the other but neither side is getting as cold as the thermostat is set to.
Any assistance would be appreciated in terms of potential things causing this: I'm mechanically inclined but no expert. I could handle changing out the thermostat if that is indeed the case but not sure where to start.
Thanks!
