Replaced the gasket on the side by side refigerator door with no problems.
Now when I close the door it does not seal tightly. I need to give the door a slight push and then it seals correctly. I have applied vaseline, etc to rubber seal and I still have this problem. If I forget to give the door a push when closing, the door will stay slightly open. When I push the door closed it seals fine.
Any suggetions would be greatly appreciated. RV
THIS FORUM IS DEAD!!!!!!! |
