Green light is on but icemaker not working or cycling. Water working in door but when I switched connectors(had to jump wires using alligator clips because connectors were different) at valves(door vs icemaker) and pushed door for water no water came into icemaker. Is this a bad valve or icemaker? If bad valve, why doesn't icemaker cycle? Part number and schematic for valve, AP3192626, show dual valves. Is this correct? Looks like a different electrical connection than the one I have? If bad icemaker, what is the part number since I found AP4345120 but it says it is a kit. Thanks
