There is no water to the dispenser or the ice maker. The single solinoid valve works OK and feeds water to the filter, but there is no water comming back from the filter. New filter doesn't help. I suspect the filter adapter (from Culligan to newer style) is bad. It has a one way valve that may not be opening properly. Any thoughts?
